Went down to our local Midnight Mayhem, TONS of ricers, wow, lol
My previous best was a 13.3 @ 103 mph. After an Intake swap, AFR 185 heads and ONLY 6-7 PSI of boost. The car pushes 430 rwhp.
The setting:
75 degree weather: about 11 pm. Las Vegas elevation, 2300 ft above sea level
Had 3 passes and my first pass was red lighted. And my next 2 passes where identical.
Remember these times are on Toyo T1-R's street tires, only 275/30 on 18 in wheels.
60ft........2.062
330.........5.593
1/8.........8.415
mph........88.93
1000.......10.818
1/4.........12.821
mph........113.59
Im still learning where to shift this bad boy. it definately likes to rev above 6k rpm. It spins alot, even 3rd gear has a alot of spin, so I have to play with the throttle down the track.
Once I fix my boost issue, (belt slip), Im changing over to an 8 rib pulley set up, should be up to 10-11 psi, I will be in the 11's I hope on street tires, then I will put on some ET Streets! Good times though. :beer:
What do you guys think of the times? On par what what you guys have seen?
The setting:
60ft........2.062
330.........5.593
1/8.........8.415
mph........88.93
1000.......10.818
1/4.........12.821
mph........113.59
