New 306 OVERHEATING?
I just had a 306 built for my 91 coupe. I used the 10.3:1 forged kit from Summit. I used AFR 165s w/ 58cc, Cometic mls gaskets, trick flow street cam/intake, long tube BBk headers, 30lb matched injectors, 76mm C&L pipe, 70mm BBk throttle body.
I had to remove the drivers side head due to the gasket being put on backwards, covering up the water jackets at the rear of the block. I installed a new stock replacement water pump, w/ a new 2 row alum radiator. 160 deg thermostat.
I filled the system from the heater hose w/ a water hose to get all the air out of the system. I let the car come to operating temp, then installed the radiator cap and drove for about 48 miles. I also let the car sit and run for over 20 minutes midway through the drive. I have an aftermarket h2o sensor on the drivers side rear intake, it was reading around 180/190 degrees, the factory front one was 150/160 degrees. Good so far.
I drove it the next morning and the temp went to 230 degrees w/i 2 mile from the house. I came home and the temp had risen to 250. I let it cool, filled it up again (it had boiled out some when it got hot) w/ the heater hose and it did fine. Again the next day, it overheated w/i 2 miles from the house.
It seems to be getting air in the system from somewhere. Any ideas or help?
I had the exact same problem after I rebuilt my 302 and had a completely dry system .. Lots of air bubbles can hide in there I know it took a good 3 or 4 times for me topping off/driving for a while. I know alot of people jack the front end up as high as they can on an initial fill and let it run that way, can't say as to how this works but wish I woulda tried it first :) As long as your not puffin smoke and/or smelling sweet stuff I'd say your ok and just still working the bubbles out.
ALOT OF TIMES WHEN A ENGINE GETS OVER 240* OR SO THE STAT CAN COLLAPSE OR FAIL . I WOULD SUGGEST REPLACING THE STAT WITH A NEW ONE AND REFILLING THE SYSTEM WITH THE CAP OFF TILL THE AIR IS ALL PURGED. YOU CAN ALSO GET A BLEEDER TO SCREW INTO YOUR MANIFOLD WATER JACKET BUNGS.
this stopped my old 306 from overheating.
You probably still have some air in there...try burping the system by pumping the upper rad hose while you are filling it up. After you think there is no air in the system, complete a pressure check to make sure the cooling system is holding pressure. Is the cap new? Also i dont know why you are running a 160° Tstat. That is too cold for our motors...you would be better off with a 180° setup. Good luck man
I would go autozone to rent a radiator pressure check. Or if you have one, to see if you system is holding pressure. And I agree that 160 is way to low. They were 195 stock, and the computer likes the engine to be warm. And hopefully u didnt warp the those heads cause of how high ur temp got
