New Alternator ????
  • Thread starter Thread starter gungfusemaj
  • Start date Start date Jul 23, 2004
gungfusemaj
211
Bradenton Fl
Jul 23, 2004
  • Jul 23, 2004
Old Stock 87 gt Alternator Going out. Is a 85 Amp A good reliable Alternator....Choices were 65,75,85 I am assuming that a stock is 65 amps.
Snouter
Libertarian Lunatic
Nov 4, 1999
2,014
Connecticut
Jul 23, 2004
  • Jul 23, 2004
I got the 130 Amp 3G Alternator from pa-performance.com years ago and it is a great upgrade. Much better than the rebuilt pieces of 65 Amp junk from Pep Boys that will go bad in 6 months.
_jb_
808
Michigan, Berrien County
Jul 23, 2004
  • Jul 23, 2004
Just upgrade to a 3G alt. I hear it takes about an hour and you will have excellent power then.
gungfusemaj
211
Bradenton Fl
Jul 23, 2004
  • Jul 23, 2004
yes that is great and all but I am on a Crunch right now. So I am taking that yes 85 will be sufficient for the time being?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jul 23, 2004
  • Jul 23, 2004
If your on a crunch...yes the 85 will be fine...I don't think it will harm the stock wiring...but I'm with the others...I got mine from www.paperformance.com and haven't had the charging problems like I did...
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Jul 24, 2004
  • Jul 24, 2004
I purchased a 130A 3G alternator from a salvage yard (from a '95 GT) for ~$50 and all the parts to wire it correctly from evparts.com for another $45.
The stock ('87-'93 non SSP) alternator's max. rated output is 60A ('87 w/ T-5) or 75A ('88-'93 w/ T-5, ALL w/ AOD). The wiring is barely adequate for 60A. Forget about 75A. And definately forget about 85A.
HISSIN50
34
129
Jul 24, 2004
  • Jul 24, 2004
im with Fox Chassis on the wiring. i hate to say it, but atleast run another wire in parallel or something. IIRC, the stock wire is 10 gauge!!
the 94-95 alt idea from FC is what i was thinking exactly. if you are getting the alt from the parts store anyhow (your 85 amper), spend a little more (esp if you are goin have to do some rewiring anyhow). more money now, but less in the end. then run a 4 gauge cable, fuse, etc and be done.
my two cents worth. good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 24, 2004
  • Jul 24, 2004
Here's websites with pictures of the 3G installation...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
For the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive
MadMatt5oh
441
St Paul, MN
Jul 24, 2004
  • Jul 24, 2004
yep, get some 4 gauge cable from the stereo store along with those cool gold terminal loops. Get some 12 gauge fusible link and run 2 strips of it in parellel instead of a fuse.
Put a 8" strip of shrink wrap over your 4 ga wire. Sodier it all together,Move the shrink wrap over the fusibles and shrink it. Total wire cost= 20$
94-95 Mustang 130 amp alt at a salvage yard = 35$
Yeah, I did alright
P
PuppyDawg
197
Boston,MA
Jul 24, 2004
#10
  • Jul 24, 2004
  • #10
yea i got one from ebay.com a while a go, and installed it the other day actually....it comes with instructions, the pieces (alt,wires,terminals) you need, and it took about an hour to do it....but wow..what a difference....i'm loving it.
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
