let me thank you in advance for your help.
-Yesterday i had complete exhaust installed. BBK equal-length shorties,O/R-X, and Flows out back. So when i pick it up its outside idling horrible. It barly makes it to the gas station a block away as it dies. i popped the hood (should've done while still there) and spy the #6 plug wire dangling in mid air
-so im like ok makes sense, put it on, check the others and start it up. idles fine. drive off=misfire?? entire rev-range ,every gear. at cruise it runs good but ANY tip-in results in misfire until you back off to cruise.
-Thinking the plug fouled while unplugged, i swap in a newbie=misfire. maybe the wire fryed while swinging next to header, so i swap with newbie=misfire?? Maybe others burnt next to a hotter header; swapped em all = misfire.
Im worried something is still unconnected since, after i convinced them the headers WERE designed for my car, they said they had to hoist the motor up in the air jus to get them to fit
considering they forgot the plugwire and all.
-Where do i look now?
Car is 94 gt 5-sp with PIH SWAP. All else is stock. It ran beautiful when dropped off.
considering they forgot the plugwire and all.-Where do i look now?
lol
