New belt=Less boost
jivepepper
776
Under a Sombrero. in WV.
After shreading the belt monday morning. I replaced it with the same size and brand. The only difference was that this belt had a slightly different pattern to the cogs on the ribs. It looks something like a goodyear gatorback, but its the by Dayco The box was faded and, I think it was like an older version.
Well I was seeing about 14psi at the top of third according to my boost gauge. Now I'm at about 12.5-13 at the top of third. I did have the one IC pipe off so I'll check there for a small leak. I want what I had before. The vacuum is the same. I need it to be the same for the 7th Dammit!! Because I'm going to the track for the first time ever. What's that **** people spray on there belt at the track?
I never ran a gatorback. I only commented that it looked like a gatorback. I ran a polycog bought times. This one just looked a little different. I think it was an older version because the cogs are spaced farther apart and the box looked old and faded.
I get belt slip but I still got between 13.5-14 psi. Now about a pound less.
hrmm ok, I thought you meant you were running a Gatorback before. Sorry..
