Well, I finally got a powertrax no-slip locker and 3.55's in my car, and ran a best at the track of 14.94 @ 95 mph on my first run. 60' time was a ****ty 2.4, no traction and a lot of wheel hop. I know it's still nothing to brag about but I'm happy so far.
Then I found out that I had inadvertently plugged my vacuum advance into the manifold vacuum port on the carb so I had around 30 degrees timing at idle.
I fixed that, so my timing was back to 13 degrees initial and then ran consistent 15.0's @94's the rest of the night, continuing with the crappy 2.4 60' times.
Also my tranny was giving me a strange problem, I was shifting manually from 1st to 2nd at around 5600-6000rpm and then the transmission would shift by itself (while the shifter was still in 2nd gear) to 3rd gear at around 5000 rpm WEIRD!! Any ideas why this might be??
And after doing the resistor wire fix, I no longer have stuttering and backfiring issues at 5200rpm, the motor revs clean to 6 grand.
I think I need to crank the base timing up, and fool around with my carb mixture and then fix the tranny issue and my times should drop even more. I think there's a lot more potential there.
