D David A Member Sep 20, 2018 80 5 18 Beaufort, SC Aug 14, 2019 #1 Aug 14, 2019 #1 I’m having a Wilwood front drum to disc brake conversion kit installed on my 65 coupe. Do I need a different distribution block or proportioning valve. I didn’t get one with the new brakes
2Blue2 will be trying this sex one when I can find it Mod Dude Mar 5, 2019 4,430 2,893 163 Oahu Aug 15, 2019 #2 Aug 15, 2019 #2 David A said: e. Do I need a different distribution block or proportioning valve. Click to expand... Yes especially if running big and littles and they have a bracket to hang it off the MC. The SSBC PV is slightly better looking Will also need residual pressure valves, 10 psi for disks and 2 psi for drums. and at this point put a line lock in for fun too, damit!
D David A Member Sep 20, 2018 80 5 18 Beaufort, SC Aug 15, 2019 #3 Aug 15, 2019 #3 Thanks for the input. The master cylinder and power boater are from Leeds. I assume the SSBC proportioning valve will work?
2Blue2 will be trying this sex one when I can find it Mod Dude Mar 5, 2019 4,430 2,893 163 Oahu Aug 16, 2019 #4 Aug 16, 2019 #4 What MC are you using again?
D David A Member Sep 20, 2018 80 5 18 Beaufort, SC Aug 16, 2019 #5 Aug 16, 2019 #5 Well the master cylinder was going to be a Leeds but it was always put on backorder so I canceled it. I’ll probably go to a Wilwood Reactions: 2Blue2
