new but old problem!?
oosmytoo
530
Portland - Oregon
i recently took my car in to get a new oil pan gasket fixed and install my headers and o/r x. also while it was in the shop they removed my smog and egr. before i took it in my car smoked a lil bit when id step on it, but now when i step on it theres tons of bluish white smoke. it will clean itself out eventually when it comes back down to an idle. checked my oil and i lost somewhere between 1/4-1/2 a quart in just a day! so now im worried and not sure what to do? or where to start even? ive been told it could be rings but they usually smoke at all times? so what else could it be? please guys i need your help! :(
thanks for the replys! i checked out my PCV valve it seems to have plenty of vacuum. but i went lookin for some kind of screen and found nothing? gonna do a compression test tomarrow, hopefully everythings ok, then ill just buy a set of AFRs and call it good for now. just as long as the smoke goes away? by putting those AFRs on there it will eliminate any chance of there being problems with the valvetrain, and if it were a head gasket? ill solve that problem too! do you really think my valves could be bad at 87,000 miles? the car has never over heated. also do you think i should put a new set of lifters in?
