- Aug 6, 2008
- 3
- 0
- 0
HI,
I am replacing the clutch assembly in my 02 mustang GT tr3650. I pulled the tranny, removed the old clutch assm. then had the fly wheel turned. I bolted everything back up and now the pressure plate teeth are too far away from the throw out bearing. This is my second clutch to install and I am unsure of how far the teeth retract in when you bolt it to the flywheel, but they are going in quite a bit. the arm that the throw out bearing attaches to almost goes all the way to the front of the alotted travel cut out in the bell housing befor it reaches the pressure plate teeth. when you push the arm against the pressure plate teeth and put the cable in there is alot of slack. when pushing the clutch in it shows no resistance until your almost to the floor. I feel like I am leaving a simple little piece out or something isnt lining up right
. Any help will be greatly appreciated! Thanks
Casey
. Any help will be greatly appreciated! Thanks Casey
