  • SN95 4.6L Mustang Tech
New engine going in!
  • Thread starter Thread starter StangGT96
  • Start date Start date Jul 1, 2006
StangGT96
94
El Paso, TX
Jul 1, 2006
  • Jul 1, 2006
My new engine is finally going to be dropped off at my house later on today! Its nothing much, its an 04 GT motor with low miles (15000 miles to be exact) to summarize its going to go on my 96 GT. My question is even though i have to change the fuel rails can i use the injectors from the 04? Also the engine is coming with the wiring harness can that be used on my 96 or di i have to use my 96 wiring harness? Thanx pics will be posted tomorrow
StangGT96
94
El Paso, TX
Jul 2, 2006
  • Jul 2, 2006
Another question Im really considering to do the engine swap my self to save some cash for LT headers and other goodies, please post any information on the engine swap. Thanx
TweekedGT
1,274
Alberta
Jul 2, 2006
  • Jul 2, 2006
Are you getting a new ECU as well or just the harness? The newer cars have a digital speedometer, only one ect sensor, traction control, and the IAT sensor and the MAF are the same sensor. Based on those few difference unless you got a new ecu with it you should use your old harness. You will have to tap a hole in the Aluminum crossover on your intake manifold to accomodate the second ECT sensor you have. I would phone a Ford dealer and ask a mechanic just to be sure.
TweekedGT
1,274
Alberta
Jul 2, 2006
  • Jul 2, 2006
Even if you did get a new ECU you would have to change your gauge cluster and I don't know if that would work since you have a manual odometer not digital.
StangGT96
94
El Paso, TX
Jul 4, 2006
  • Jul 4, 2006
No I'm going to use the old ECU. Anybody ever rremoved the engine from a mustang? Is it simple?
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 4, 2006
  • Jul 4, 2006
well, it's kinda simple
the toughest part is usually removing trans bolts off the block, sometimes well most of the times either of the two top bolts will be stuck in and you'll have a very hard time trying to get a grinder in there to cut the bolts off
StangGT96
94
El Paso, TX
Jul 4, 2006
  • Jul 4, 2006
Well i'm going to start today. on the chilton's book they remove it from the top, but I have seen people remove the engine from the bottom, is there some kind of reasoning behind this? Also i'm installing some long tubes kind this make the instalation complicated fitting the engine back?
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jul 4, 2006
  • Jul 4, 2006
Dont we know that....
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 4, 2006
  • Jul 4, 2006
use everything from the 96 motor, you do not need the 04 harness or any of the other 04 stuff. This swap is a direct drop in except for the second ECT sensor.. All you do is a T-fitting for that and problem solved.
W
Will Smith
191
Cape Coral, FL
Jul 4, 2006
#10
  • Jul 4, 2006
  • #10
if u have access to a lift it might be easier just to drop the trans and the motor at the same time and bring it out the bottom. just drop the K member and disconnect what u normally would and just have everything come out the bottom.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
