New Engine - how do you prime the oil pump?
Just wondering what other peoples experience has been with this. I have just recently ordered a MMR Mod 600 shortblock and will be assembling the rest of the engine myself. My question is; how do you prime the oil pump so that you have oil where you want it when you crank that bitch over for the first time? I have seen other engines primed using a notched shaft affixed to a cordless drill but i just don't see how one would do that on a modular engine. I am using a Ford Racing High Volume oil pump on a cast iron block if it makes a difference. Thanks!
When the engine is built assembly lube is used in key places to avoid a dry start. This assembly lube dissolves immediately in motor oil.
Also, you can hold the gas pedal to the floor when you crank the starter. Holding the gas pedal down will prevent the engine from starting. The cranking will circulate oil.
Also, Ford Racing Performance Parts sells an oiling pump for modular engines for this exact situation. The pump connects where the oil pressure sending unit is and you use it to pre-lube the engine with oil prior to the initial start. Here is a link to it: http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=8228
