new engine=new problem, help!
mustanghunter50
123
easton pa
i put a reman 5.0 in my car a few weeks ago. the motor starts fine and runs real well, but i can tell the timing is off a little bit. we put a gun on it and where it should be, the car wont start, so i turned it a little to the right, around 1230-1 oclock. the car runs well, but after a while when it's at normal running temp, if i put it in neutral, the car will die. it starts right back up, and i have to feather the gas to it doesnt stall. anyone have any ideas?
Info for cleaning the IAC.
Info for setting timing.
Set your timing first and the other issue very well might fix itself (If you tried to get down to 14* or so with the SPOUT in, you retarded the timing so much that it will try to stall). Nice catch 86 BC.
Good luck.
