I have just got my new engine running last weekend and I'm having a small problem (some things were expected). I have never done any major tuning as I had a mostly stock car. I am still running a stock maf, TB, heads(lightly ported), intake, and stock 24lb injectors. I am however running a crower 15511 cam, mac 1 5/8 shorties, CAI, and O/R x pipe. All of this is on a stock j4j1 tune with the smog and egr turned off and some minor tweaks to the timing tables as of right now.
The problem is a lean condition which is triggering a CEL for both banks running lean O2's not switching. The car will go into closed loop for several seconds and the O2's will read .512-.537. The lambse's will go all the way down to 10.92 and the car will almost die when it does this if it's idling. The Kam's will never become active. The car will go back into open loop and not switch back to closed loop again. The O2's are new and read exactly the same as the old ones did. I have checked for vaccum leaks and have found none. I need to get a vaccum gauge to check to see how much vaccum it has.
I have got EA downloaded but I haven't got it registered yet it will be Friday before I can do it as I've spent all my money getting the car running. Where do I need to start to get everything right? I know there is gonna be a steep learning curve doing all this and forgive me if I've missed something that needs to be done or didn't give all the information needed.
Thanks in advance, Jarad
