- Dec 6, 2009
- 1
- 0
- 0
Whats going on, im new to the forums from Missouri and also new to the "Mustang Scene" I just recently acquired a 92 LX 5.0 hatch with quite a lot of bolt ons. I got a good deal on the car I couldn't pass up I traded a 97 Eddie Bauer Explorer that I had $2500 in and had 221xxx miles on for this car, I think it was worth it... the car needs painted but runs awesome...here is some pics of it
Here is a list of mods on the car:
Trickflow Twisted Wedge Heads
Trickflow 1.6 RR
6.75 Harden Pushrods
Comp Cams xe270-14 w/Comp Cams Lifters
Ford Racing Valve Covers
Holley Systemax II Intake w/1" Spacer
70mm PP TB and egr spacer plate with egr delete kit
BBK cold air intake with 76mm mas calibrated for 24 lb injectors
BBK adj fuel pressure regulator with fuel pressure gauge
E3 sparkplugs
9mm Ford Racing wires
MSD cap rotor and coil
new A9L computer
BBK polished pullies
ceramic shorties x-pipe flowmasters with 3" dumps
oversized raidator with dual electric fans
lightweight aluminum flywheel
hurst short throw shifter
aluminum drive shaft
3.73 gears
ranger axles
95 5 lug spindles
13" cross drilled rotors
bullitt calipers
new a arms with poly bushings
tokico hp struts + shocks
Eibach sportline springs
New rack with tie rods
BBK caster camber plates
stainless tube upper lower control arms
18x9 and 18x10.5 cobra r rims
3 " cowl hood
5" tach with white faced cauges
Theres probably more I just can't remember it all, it needs a few things like some exhaust leaks buttoned up and some new gaskets and a new battery but nothing major.
Trickflow 1.6 RR
E3 sparkplugs
new A9L computer
3.73 gears
ranger axles
95 5 lug spindles
bullitt calipers
3 " cowl hood
