new fuel pump same bull**** problem
  • Thread starter Thread starter noslow1986
  • Start date Start date Jan 16, 2007
N
noslow1986
274
oswego Il
Jan 16, 2007
  • Jan 16, 2007
just got my car back and still have the same problem. high rpm miss. like a rev limitor. now the shop says all systems ok. so i decide to check tps i cant get a reading at all nothing. they block off egr valve and i disconnect it and cap it off. shop says its still running lean is what they said.how could i check my distribtor to see if there is a problem there. the tfi module is brand new
z2o_what
309
princeton, WV
Jan 17, 2007
  • Jan 17, 2007
did you check to see if the tps was getting power, from the orange wire(i think its like 4volts) . when my car was efi i had alot of problems with it missing, and it turned out the orange wire wasn't in the plug far enough to get connection.
N
noslow1986
274
oswego Il
Jan 17, 2007
  • Jan 17, 2007
put a multimeter on it and cant get a reading even tried a different one. new plugs, cap,rotor wires,tfi module, oxygen sensors, 2 different coils, fuel filter, i dont know what to do i already had then pump put in and it some what fixed the problem but the high rpm miss is still there. been dealing with this for 2 months. how can i tell is the distrubtor is good. i cant even check tps for whatever reason it wont let me.
HISSIN50
34
129
Jan 17, 2007
  • Jan 17, 2007
You have the key-on while doing this, right?
Put the DMM across the battery terminals as a bench test. If it works there, reprobe the TPS wires. They can be a bear to pierce decently. If needed, check each wire (checking for continuity to ground with the TPS ground wire).
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 17, 2007
  • Jan 17, 2007
A repeat of what I have said before...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
You may not be running lean, but may have other problems. Lack of fuel is not my #1 suspect in high speed misses. It is usually ignition related.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
