New gauge setup
02TruBlueGt
So long story short my cousin John has been developing his own series of gauges over the past 2 years. Well they are finally ready and i became test dummy for first set to be put in a car. The 5 in tach works flawlessly (after alot of software changes) with the ingnition in the edge mustangs, and also has its own built in nitrous control and traction control and water/meth control. The water temp gauges controls the fan with its hi/low settings that are user programmable. The air/fuel gauges can be set to be either narrow/wideband with the push of two buttons on the gauge. Mine is a narrow until i can afford to order a wideband sensor and unit. He a full lineup as well as boost gauge that doubles as a boost controller. Each gauge has 7 different programmable colors, Hi/low settings, Pointer brightness settings, dimmer settings for dimming them when headlights are turned on. Backlight brightness,peak playback and more all user programmable. The tach features its own built in shift lights. The black spots on the tach when reved in the low zone will light up yellow as you rev higher. Once you reach the programmed Hi level all the lights light up red( this brightness also changeable). Well so you guys can see what im talking about here is a pic of them in my car.
Price range depends on gauge and extra programming you want with the gauges. Im pretty sure the gauges will run around 150-250 and the tach with base programming being around 350 and if you want nitrous,water/meth and traction control programmed in will be an extra 100. More prices will be def when the new website is up and running later this week, but i may be able to do a group buy since hes my cousin and maybe work a discounted price.
www.propartsllc.com of you have adobe reader i believe you can see there old website with pics on there for more info. Each gauges can either come white black or silver faced with a polished,black,chrome bezel ring. Oh and, the 5 in tach works in a 2 in pod thanks to the adaptor he makes. Each gauges comes with a premade harness to plug and play and there are no gauge controllers needed like for instance defi gauges. Each gauge can also control each other. Say you have nitrous to spool up a turbo on a drag car, well ypou can set the boost gauge controller to 30psi for instance and the boost gauge will tell the nitrous to stop spraying once your turbo makes 30psi.
The tach is mounted to the pillar with an adaptor. He does have NOS pressure reading up to 1600psi. I will take some pics myself to show more angles of the gauges and how the tach is mounted and post them tonite.
