New Guy lots of Questions
I need your thoughts/opinions
New mustang owner here, decided to sign up to get some opinions out there. Give you a little background on the car, 92 calypso notch, E303, Edelbrock heads, 1.6 rockers, Cobra intake, long tubes, flowmaster 40's, bbk ca intake, 70mm tb, not sure if the injectors are oversize or not, crane cams fireball ignition. 100 shot of nitrous. Car has 50,000 miles, in absolutely beautiful shape but a lot of these mods were done a long time ago. I have decided to put it down for a while and go through some leaky gaskets, bad mounts, hide some wires, clean rusty headers, etc. since the tranny is aggravating me.
Tranny- If I am accelerating as the clutch is coming off, it will stay in second. Like when you would take off from a stop sign and continue driving normal. However, If I am not mashing the gas while letting off the clutch, it will not stay in second. Like when going from third to second to decelerate for a turn. I feel like I have plenty of clutch in the pedal. Compared to my fathers T5, mine seems a little clunkier in the shifter and the pedal is harder to press, but I wouldnt think it abnormal. My transmission is a factory 92 t5 with hurst short shift. The clutch cable is one of these deals with the adjustable firewall mount. After every good cruise I have to readjust the thing all the way out to get good pedal. For some reason that thing wont stay in adjustment. I am rebuilding the T5 in about a week and want to know, with the typical rebuild kit will this second gear problem be solved or do I have a bad shift fork or something that I need to buy in addition to the kit? I am going back to a factory style clutch cable. Car has 50,000 miles on it and around 330 horsepower. 3.73 rear end. I am sure the clutch is probabley stock, by the way, the nitrous has never been used. I knew the prior owner and he hadnt used it. I havent used it. I know T5's arent supposed to like the nitrous. I dont want you to use this in your tranny diagnostic.
Intake- for my bbk fendermount air intake, where can I buy the rubber couplers that hold the peices together? I dont know if I have overlooked them on a site somewhere but I dont want a new intake, just the rubber couplers, these are looking tired. BTW, I dont care if they are BBK or not, would prefer grabber blue. Plus the P.O. cut a huge hole in the upper coupler and shoved the nitrous sprayer in it, there has got to be a better way to do it. Any good looking suggestions?
Mounts- What motor/transmission mounts do you guys recommend?
Long Tubes- Should I be able to pull those off without lifting the engine? Im gonna give it a shot but worse comes to worse I gotta do the mounts anyway.
Thanks for any of you guys help. Its really appreciated.
I'm no expert on them but it sounds like the tranny has been hammered on pretty hard. Have you changed the fluid to see what it looks like or see if anything other than fluid comes out. You might have a bad syncro. Does it grind when you shift from first to second? I would bet on a worn out clutch also.
Leave the adjustable clutch cable setup in. Down the road you wont be sorry. The only factory replacement is the cheap and poorly designed plastic quadrant that is not adjustable and can break. Besides, if you dont have to get your hands up in there to replace something that is not broken, DONT. Its a real PITA! One last thing about the adjustable cable. There should be a set screw to keep the adjustment where you want it. It is usually just an allen screw right on the piece on the outeside half of the firewall.
Yeah I have tried adjusting the allen but it just doesnt seem to hold well. Read a couple of other similar tranny problems on the thread and the general consensus seems to be synchros. The car really hasnt been slammed on to much but who knows. I am going to be replacing the clutch anyways so that will knock out the disc theory. Thanks for replying, I know I wrote a book. By the way, you guys with the adjustable cables, are you having to adjust it all the way out or is that a sign of a problem?
I hate hate HATE adjustable cables. Its not if, but when it will stretch and fail. If you cannot find a ford replacement cable then go with the maximum motorsports cable. Also if you you dont have them already get the MM firewall adjuster and clutch quadrant. The stock quad is plastic and over time it will stress and start to bend/flex with pedal movement.
As for the rubber couplers you can pick them up at home depot in the plumbing dept.
Lose the BBk intake completely, get an anderson NA power pipe, especially if you are hiding wires (which means you care how things look).
The trans needs a small parts rebuild likely. Should run you like $500 total.
