- Feb 21, 2011
- 6
- 0
- 0
Hello, new here, been reading for a while though. I have yet to get the project car, but do have block to start playing with. I have a '67 or '68 mercury 289 block my grandfather had squirreled away that I want to use as the heart to my beast.
I know all about the stroked 302 and what not. Is there anything I can do to the 289? I really want to use this block. Everything else my grandfather left I either sold(by request of my grandmother) or wrecked (thank you Michigan winters). I am not looking to take it to the strip, but right around 450 hp would be what I am shooting for.
Is that even possible, I am mechanically inclined, so I will be doing as much as I can to cut costs.
I will need heads, rotating assy, pistons and rods.
Also, I run a salvage yard, so if there are any intakes or heads I should look for, I can probably find.
Thanks in advance
Thanks in advance
first off if you're having to worry about the 289/302 being a "stronger block" you're doin something wrong. secondly you don't HAVE to add zinc and you can just run diesel grade oil if you're that worried about it.
you might surprise yourself.
