  • SN95 4.6L Mustang Tech
new H-Pipe install question
  • Thread starter Thread starter 99prmustang
  • Start date Start date Feb 5, 2004
99prmustang
141
  • Feb 5, 2004
hey6 all i jsut got done installing my new mac h-pipe on my gt.
it sounds like there is a leak on the passenger side header to pipe connection but i see not smoke or feel no air. could this just be the sound of the pipe breaking itslef in? do they even do that? thanks
99prmustang
141
  • Feb 6, 2004
once again those of you on stangnet have failed me again. is it so hard to answer a simple question? i used to be a thirdgen firebird owner, and the people on thirdgen.org where amazing on that message board, always had a helpful answer to all questions, i am on my second stang now, the 5.0 guys where always very helpful when i had my 89 gt. but i have been dissapointed more than once on the 4.6L board here on stangnet. thanks alot
road rage
433
R.I.
Feb 6, 2004
  • Feb 6, 2004
Start your car up and go to where you think the leak is. Take a piece of paper (notebook paper works best). Hold it close to all points around where the header and pipe meet, if there is a leak you will see the paper move where the leak is. Hope this helps good luck.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Feb 6, 2004
  • Feb 6, 2004
did you replace the studs coming out of the manifold , if you didnt thats your problem , replace them that way you can get the flange good and tight , problem solved
blueovalguy
1,364
York Haven, Pa.
Feb 6, 2004
  • Feb 6, 2004
Before you start slamming all the good folks in the 4.6 forum, look at your original post. It took me 2 or 3 times to figure out what it said. Spend a little more time composing your message and you'll get more answers that way.
When installing a new H-pipe, make sure you tighten the passenger side(solid mount) first, then go to the driver's side. I had absolutely no problem with my MRT H-pipe. You get what you pay for!
BennettDMB
152
Richmond KY
Feb 6, 2004
  • Feb 6, 2004
Did you put the gasket that's on the passenger side back on?
99prmustang
141
  • Feb 6, 2004
sorry for slamming you guys, i jsut need an answer asap. i didint replace the studs, so ill do that when it stops god damn snowing up here and yes i put the mac gasket in that came with the pipe. one other question is did the factory h-pipe come with a factory gasket at the pass. side header?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Feb 6, 2004
  • Feb 6, 2004
yes it did , thin metal one , with raised packing material that fit in a groove on the factory manifold / hpipe connection. should have fell out when you took down the old one or its stuck to the hpipe or manifold .
if the mac came with a metal type gasket sometimes they will leak when cold very very very slightly but seal up once they get hot , if it was a thick paper type it should seal good but will blow out under alot of pressure . change the studs and take the factory gasket to a parts store and match up if yours is blown out already since you probably didnt get it tight enough because of the factory studs , might have to do some trimming to get one to fit good , just make sure it seals all around and bolt holes line up , get a metal one , it will last longer and hold more pressure from blowing out
99prmustang
141
  • Feb 6, 2004
ok...my whole problem is i thinnk i forgot to remove the factory one when i put the mac one on...i no i no that was stupid of me, but i think that may be my problem????
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Feb 6, 2004
#10
  • Feb 6, 2004
  • #10
that will do it LOL
JonJon
4,801
back in Marylands
Feb 6, 2004
#11
  • Feb 6, 2004
  • #11
Spraying soapy water from a spray bottle works too. you'll see bubbles
whee
99prmustang
141
#12
  • Feb 7, 2004
  • #12
2002BLGT said:
that will do it LOL
i have had it one for two days of so now, and it continues to pour out white smoke, i no its cold and cars do this in the winter, but it just seems like there is alot of excess white smoke....is this normal, did i damage my O2 sensors? help!!!!
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Feb 8, 2004
#13
  • Feb 8, 2004
  • #13
have you fixed your leak yet ??? smoke is probably just the added condensation in the pipe from sitting overnight . its alot more noticeable with offroad pipes
99prmustang
141
#14
  • Feb 8, 2004
  • #14
thank you....no i havent gotten to fix it yet, today was the frst dry sunny day we have up here in my part of MA im gonna try to get to it today, i think i might wait till mid week and jsut fix it when the cat-back comes in and do it all at once
i have another question about MILs is it better to get the 60 dollar ones form dallas mustang, or the ones from http://www.mileliminators.com/ for 30 bucks?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Feb 8, 2004
#15
  • Feb 8, 2004
  • #15
get the cheaper ones , or look on here there is a post on how to make your own with about 10 bucks from radio shack .
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
