I have two new problems that have just started. I drove my car to the dragstrip Sat. and I got in the car to drive to the staging lanes and it ran fine. I cranked the car to pull out on the track and it idled at 1200-1800 rpm's (it's normally around 800) but was otherwise ok so I made my pass but didn't make any more due to this problem.
On the way home I floored the throttle and got severe detonation it's never done that before so I let off immediatly and drove a little further and done it again but this time it ran fine
I done some datalogs with the tweecer and found that when I'm getting detonation the spark advance is showing 44 degrees but most of the time it's normal.
I also noticed that at idle the throttle status is showing part so I checked my tps voltage at idle it's 1.35 WOT 5.35. I set this two months ago at .93 at idle now the lowest I can get this is 1.22. Could this be my problem? I'm begining to think my tps sensor is going bad but I don't know if that could cause my detonation problem.
I also noticed the load% was showing 119 if that had anything to do with it.
I'm going to look at some of my old datalogs to see if I can find anything more.
What do you guys think?
