New heads
  • Thread starter Thread starter 885.0conv
  • Start date Start date Jul 25, 2009
885.0conv
238
Phoenix, Az
Jul 25, 2009
  • Jul 25, 2009
I was just wondering about how long does it take for new heads to break in (when the are at there best hp wise). Are they pretty much the same hp when you bolt them on or do they get better? Could be the tranny since its automatic but it seems that some mornings I have more kick when stepping on the gas. Maybe a shift kit would keep it in the higher kick range.
347HO
462
Seattle
Jul 25, 2009
  • Jul 25, 2009
Head don't get "better" with usage.
In almost every case, they lose performance.
You have to consider the beating the valve seats take.
Valve springs lose their tension, especially do to improper oiling.
Normal buildup of deposits.
old_blue
1,783
282
124
Jul 25, 2009
  • Jul 25, 2009
morning is probably due to the colder air you are sucking into the intake and will make it run better. As the engine warms up and outside temperature warm up the performance will start too suffer.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jul 25, 2009
  • Jul 25, 2009
+1, Its mostly due to the temperature difference. As the engine begins to soak in heat, and as the outside air temp increases, the engine will make slightly less power. I notice it in my car too. Also, cars tend to perform better in the early spring/late fall, when air outside is nice and cool, which makes it more dense. Same concept behind a "cold air intake".
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
