New Heads
  • Thread starter Thread starter quicksilver075
  • Start date Start date Sep 13, 2013
1 of 2 Next Last
Q
quicksilver075
94
11
  • Sep 13, 2013
I got the new heads for my car yesterday. Can't wait to start the build up.
hoopty5.0
mechanicus terribilis
7,854
6,994
214
SW Houston
Sep 13, 2013
  • Sep 13, 2013
Last thing i heard about those was the springs that they come with were trash. Was this corrected?
Q
quicksilver075
94
11
  • Sep 13, 2013
It has not been corrected. I also ordered the spring kit from Ed at flowtech induction to replace them. I'm running the comp cams stage 3 cam XE270HR, that was delivered about an hour ago, so I knew I was going to need to replace them. I just could not beat the price even with the spring upgrade.
hoopty5.0
7,854
6,994
214
SW Houston
Sep 13, 2013
  • Sep 13, 2013
Understandable. Keep us posted
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Sep 13, 2013
  • Sep 13, 2013
tru dat playa, foshizzlemynizzleforizzle!!!
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Sep 13, 2013
  • Sep 13, 2013
Curious what intake for that 270, gonna dyno it too??
Q
quicksilver075
94
11
  • Sep 13, 2013
I got a deal on a typhoon intake ( edlebrock nock off ) but i ported it matched the gaskets and polished up the runners in it really good. Spent half a week working on the inside of it, after work. I probably will get the car on a dyno when I'm done just so I know what I built. I am really hoping for 300+rwhp. It should be plenty for the wife.
Q
quicksilver075
94
11
  • Sep 13, 2013
I should add I'm also running a bbk 70mm throttle body and bbk headers, 24 pound injectors and mass air sensor or at least that's what I bought to run. I'm sure some things will change along the way. Any recommendations on a stall speed? I think 2200-2500 would be good. How about a good balancer? I need to get one still.
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Sep 13, 2013
  • Sep 13, 2013
You should get that with that cam good luck!!
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 13, 2013
#10
  • Sep 13, 2013
  • #10
It's good to see someone do some research before they purchase. My understanding is that those heads work great with the spring upgrade. Let us know how they work out in the end, and how much the heads ended up costing you assembled if you could.
Kurt
88LX5.Oh
1,442
205
94
Arkansas
Sep 14, 2013
#11
  • Sep 14, 2013
  • #11
Now you're making me wish I had upgraded my springs when I got those heads. Oh well I just have a B cam lol.
As for stall speed, I'd go with what you came up with. And also that cam is designed to go with 1.7 rockers. So if you end up using 1.6's you're gonna lose a little lift. Just letting ya know because most people don't think of this or even see it in the products description
88LX5.Oh
1,442
205
94
Arkansas
Sep 14, 2013
#12
  • Sep 14, 2013
  • #12
BTW are these the 2.02/1.60 heads or the 1.90/1.60 heads?
Q
quicksilver075
94
11
#13
  • Sep 14, 2013
  • #13
They are the 1.90/1.60 heads just got them back from the shop today and they look great all ported and polished up inside. I do have a set of 1.7 roller rockers for it as well. My buddy came over and installed the cam in the block today, he knows how more about degreeing a cam than I care to learn and he has the tools to do it. I managed to miss place the dang cam gear bolt so we quit for the day. I still have to put the heads back together then I can bolt them on.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 14, 2013
#14
  • Sep 14, 2013
  • #14
You should be fine with a Factory replacement balancer. If you want something a little better get the Pioneer SFI approved one.
Kurt
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 14, 2013
#15
  • Sep 14, 2013
  • #15
Can't believe the E brock heads still haven't address the springs... I bought a set of performer heads way back when and the damn springs ate through the pads, plus the guides were absolute crap. Glad you had yours checked out before install.
Q
quicksilver075
94
11
#16
  • Sep 15, 2013
  • #16
Kurt
How about this one from summit?
Summit Racing SUM-163302 - Summit Racing® OEM Harmonic Dampers
http://m.summitracing.com/parts/sum-163302
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 15, 2013
#17
  • Sep 15, 2013
  • #17
Looks Chinese. I would pass. The oem one is cheaper than that anyway.
Kurt
Q
quicksilver075
94
11
#18
  • Sep 17, 2013
  • #18
New spring kit came today. Along with the comp 1.7 rocker arms. Hope to check PTV clearances by the end of the week. Things are coming along.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 17, 2013
#19
  • Sep 17, 2013
  • #19
Do you have access to a spring checker? It wouldn't hurt to check the pressure and bind on them before you bolt them down.
Q
quicksilver075
94
11
#20
  • Sep 19, 2013
  • #20
Well checked PTV Clearance and failed with stock pistons. It tore thru the clay guess trying to use a stock bottom end was a bad idea. Anyone have a recommendation on a set of pistons with better valve reliefs. Thanks
1 of 2 Next Last
90 mustang no spark
  • djj62478
  • Nov 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 6:35 PM
djj62478
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
