It is brand new still in the box. Never got around to installing it. My loss is your gain.
$100 shipped
Alpine V-Power Series 4/3/2 Channel Amplifier, Model MRPF240
This ultra versatile amplifier offers both Speaker level and RCA inputs with HP/LP crossovers making them perfectly designed to work with any radio or any system. The V-Power amplifiers enhance numerous system building designs with superb performance and value. It also has a Bass EQ for that extra kick and is Bass Engine® ready making it perfect for all Alpine head units.
Key Features:
* 360W Max Power (EIAJ)
* 14.4V RMS Continuous Power
4ohm; Stereo (0.08% THD) 40W x 4 2ohm; Stereo (0.3% THD) 50W x 4 Bridged 4ohm; (0.3% THD) 100W x 2
* S/N Ratio 100 dBA
* Bass Engine®
* 18dB HP/LP (80Hz) Crossover
* 4 Volt Input Capability
* STAR Topology & Duo-B Circuitry
* Darlington Bi-Polar Outputs
* MOSFET Power Supply
* Non-Fading PreOut
* Speaker Level Input
* Blue Power LED
Features:
General
* Bass EQ
* Crossover (HP/LP)
* Subsonic Filter
* 4/3/2 Channel Operation
* Bass Engine®
* Continuously Adjustable Gain Control
* Cross-Vented Chassis
* DC-DC PWM Power Supply
* Discrete Pre-Amp Stage
* Double Buffered Pre-Amp Input Circuitry
* Duo ß Feedback Circuit
* Gold Plated Power Screw Terminals
* Gold Plated RCA Input Connectors
* Gold Plated Speaker Screw Terminals
* MultiMode™
* Noise Elimination Coil
* Non-Fading Pre-Amp Output
* STAR Circuitry
* Speaker Level Inputs
* Top Mounted Blue LED Power/Status Indicator
Specifications:
Bass Engine®
* Bass EQ Frequency (Fixed): 50Hz
* Bass EQ Level (Selectable): 0-12dB
* Crossover Type: 18dB/oct
* Low/High Pass Crossover Frequency (Fixed): 80Hz
* Subsonic Filter Range (Fixed ch3+4 s/LPF engaged): 15Hz
General
* Dividing Network: Fixed 80Hz HP/LP (18dB/oct)
* Frequency Reponse: 10Hz-50kHz (+0,-1dB)
* Input Impedance: 10k ohm
* Input Sensitivity (for rated power): 0.2V - 4.0V
* Power Requirements: 14.4V DC (11V to 16V)
* Signal to Noise (S/N): 100dBA (referenced to rated power)
* Slew Factor: greater than 5
* Speaker Impedance: 4 or 2 ohms(stereo), 4 ohms(bridged)
MAX Power (at 14.4V,EIAJ)
* Bridged 4 ohms: 360W x 2
* Per channel into 4 ohms: 75W x 4
RMS Power (at 14.4V,20Hz-20kHz)
* Bridged 4 ohms: 100W x 2 (0.3% THD)
* Per channel into 2 ohms: 50W x 4 (0.3% THD)
* Per channel into 4 ohms: 40W x 4 (0.08% THD)
Approximate Dimensions:
* Foot Print
o Width: 9-1/2”
o Height: 2-5/16”
o Depth: 10-1/2”
* Heat Sink
o Width: 9-1/2"
o Height: 2-5/16"
o Depth: 9-1/8"
$100 shipped
Key Features:
* S/N Ratio 100 dBA
* Bass Engine®
* Non-Fading PreOut
* Blue Power LED
Features:
General
* Bass EQ
* Crossover (HP/LP)
* Subsonic Filter
* Bass Engine®
* MultiMode™
* STAR Circuitry
Specifications:
Bass Engine®
General
* Foot Print
o Width: 9-1/2”
o Height: 2-5/16”
o Depth: 10-1/2”
* Heat Sink
o Width: 9-1/2"
o Height: 2-5/16"
o Depth: 9-1/8"
