Memphis belle 5ch amp
Kornnut
1,999
48
108
Tulsa
I have a memphis belle 5ch amp that I don't use any more. Had it in my car and never drove the car. Decided to take it out. I will take $225+shipping for it, or trade for some very specific parts or combo up to the value listed(within reason). Specs listed below. I do not have paypal.
Trades accpeted
Trick Flow Plenum(black finish) for a mod motor
MM Torque-arm spring, Street Performance, pair
Bumpsteer kit, 1994-04 Mustang, tapered-stud style from MM
Steering Shaft Assembly, Power Steering Rack, 1994-04 Mustang from MM(Trade amp straight up for this)
H&R Mustang Super Race Springs, set of 4(Trade amp for these straight up)
17x9 bullitts from AM(Trade amp for these straight up)
5-Channel MClass Series Amplifier
Class-AB / Class-D Hybrid Amplifier
Compact Aluminum Chassis with Custom Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
4-Way Protection Circuitry
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 20.85" L x 7.6" W x 2.4" H
Number of Channels 5
RMS Power (4 ohms) 55 watts x 4 chan. + 100 watts x 1 chan.
RMS Power (2 ohms) 75 watts x 4 chan. + 200 watts x 1 chan.
RMS Power (1 ohm) Not Stable + 400 watts x 1 chan.
Bridged RMS Power 150 watts x 2 chan.
Peak Power Output 1400 watts approx.
Min. Impedance Unbridged 2 ohms (Channels 1-4), 1 ohm (Channel 5)
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.03%
Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz) + LP (50 - 250 Hz), Subsonic (20 - 50 Hz)
Signal-to-Noise Ratio 95 dB
Fuse Rating 25A x 3
