New Joiner
  • Thread starter Thread starter 67-Coupe
  • Start date Start date Mar 14, 2007
67-Coupe
N. Georgia
Mar 14, 2007
  • Mar 14, 2007
Hey ya'll - I've been looking around on the web and found you guys a while back. I'm starting some mods on my car and wanted to drop in to research rear gears. So after reading it all I'm looking for some thoughts.
My Car:
67 Coupe 351w, edelbrock performer heads, intake manifold, 650cfm holly dblpumper w/ mechanical secondaries, headman headers. Never had it dyno'd but guessing somewhere between 320 and 360 bhp. Not much more to do to the engine other than upgrade the ignition (I don't think)
Tires: 265 70 15s though I think I'll downsize a bit - too much rubbing on the wheelwell. Someday I'd like big rims and smaller tire...
Current mods underway:
New T5 with a 2.95 first gear and .64 OD
install Rear locker
upgrade rear gear
Caltracs traction bars
upgrading to new clutch cable instead of old linkage
install Powerboost brakes.
It's probably never going to see the track though I do drive aggressively and don't want to be shown up by any 4bangers with a turbo. You wouldn't believe how many yahoos in a new dodge ram with a hemi want to race me! Actually, you probably do!
It has a 8 in rear end and I'm trying to decide what rear gear to put in. I guess the question is how much do you lose in a 3.55 rear gear versus 3.73 or higer? I don't mean RPMs, I mean acceleration or performance. It's not a daily driver and I know I'll get all kinds of answers ranging from 3.55 to 4.3. I just need to figure out which is right and not regret what I put in. Same decision going with the 351 over the 302.
Thanks!
David
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Mar 14, 2007
  • Mar 14, 2007
Have u upgraded to a hotter cam? If so, I would go 3:73 or maybe a little lower/ if cam is stock, 3:50 is fine. Definitley stay with the 351W; you jave a nice start there. Welcome!
R
Rapid
297
Columbia, SC
Mar 14, 2007
  • Mar 14, 2007
My Car:
install Rear locker
upgrade rear gear
Thanks!
David
Welcome Back. I just finished a T5Z swap myself and had asked about gears. I have decided to go with 3.50s and a Tru Track limited slip. MIne is a daily driver and I want to keep it flexable. You will really appreciate the OD.
67-Coupe
N. Georgia
Mar 15, 2007
  • Mar 15, 2007
It does have a little bigger cam in it. Sadly, I don't remember the specifics, it was a few years ago.
zookeeper
3,415
63
109
Rogue River, Oregon
Mar 15, 2007
  • Mar 15, 2007
351's have a ton of torque, so for the street you can get away with taller gears. I don't know how often you drive on the freeway, but a 3.73 with a T5 trans would make a good stoplight-to-stoplight setup without sarcificing too much on the freeway. I've used 3.89 gears with a 4 speed and I hated it. It was great in town, but miserable on the freeway, but that extra gear would really help you get the rpm's back down.
68EFIvert
639
Camas, Washington
Mar 16, 2007
  • Mar 16, 2007
I have a t5 and decided to go with 3.70 W/Trac Lock in my car. There are a few places on the net that you can plug in your specifications, tire size mine are about 26" tall), final drive ratio (tranny overdrive) and sample gear ratio and it will give you what RPM you will be cruising at highway speeds. I think it came at 2200 @ 60 -65 RPM with my setup (where the power band starts with my cam). I had to purchase a 21 tooth speedo gear to calibrate the speedo. Here is a link for a calculator. http://www.carforums.net/rearcalc.php
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
G
Expired 2013 Ford Mustang V6 (Grabber Blue) 3:55 gears... Excellent Condition.
  • Grabberblueguy77
  • Nov 19, 2025
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Mar 11, 2026
Grabberblueguy77
G
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
