New motor in car, It wont Start HELP ASAP!!!
5.0 Mustang Man
234
New Mexico
:shrug: :shrug: I just dropped a stock 302 HO in my 91 LX because the old motor spun a bearing. This is a stock 302 out of a 90 Lincoln, it is exactly the same as a mustang 5.0. I used all the accessories and wiring from my 91. Everything works and it cranks over but will not start. I re stabbed the distributor several times, tried another distributor, know the wires are right etc. It has fuel pressure on my gauge and has spark. The only thing I can think is that the injectors aren't actually spraying fuel into the intake. Could a bad mass air meter cause this? Wouldn't it still start atleast? I did hear a few intake pops a few times but it still didn't start. I know my way around 5.0's pretty well and I have never had a problem like this on this car, my other mustangs, or my friends mustangs. Any help would be greatly appreciated. Thanks.
Are you sure the Lincoln motor is a 5.0 HO and not a regular 5.0? The low output 5.0 had a different firing order, and so it would not start with the plug wires aranged for a HO. A bad mass air meter wouldn't cause it not to start, well shouldn't anyway. But I suppose it is still possible, try it witht he meter unplugged. Also, did the engine run in the lincoln?
Yes it is a High Output motor for sure. I was told it ran and I saw the car it was pulled out of (totaled in the rear end). It came from a reputable salvage yard and I'm pretty sure the motor will run, I just cant figure it out. Could my computer of went bad while the car was sitting? It only sat for 3 months with no motor in it and the wires all just laying in there. Any more ideas? I'm going to attack it again in the morning, i really need my car fixed as this is my only street drivable car and i'm sick of driving a carbed race car to and from work. Thanks again.
I too, assume that your motor does not have the 5.0 firing order.
Assuming that you have checked for spark and fuel, then I assume that you have the injectors and the dist in the firing order.
Take some time to veriify that everything lines up.
Before ruling it out, take a few minutes to check it out.
Sometimes those distributors can be really tricky. Keep trying that. And try the non HO firing order, just in case. I have seen a friened reshoot his disributor at least 20 times, then finally convinced him to put it in 180* off, and that solved the problem. I guess sometimes you're not on the compression stroke when you think you are.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer
E.) Fuse links in wiring harness
F.) Ignition switch
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – Coupe -& hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
4.) Spark & fuel OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
D.) Firing order off: HO & 351 use a different firing order form the non HO engines.
I finally got it to start after spraying a lot of ether into it and then it just died a few seconds later. It sounded like crap too. It was real irratic and sloppy sounding. Then my starter went out so I put another starter I had in and it just died too. Every time I crank it over it sounds horrible. It is like a shearing noise as the starter turns over. I'm to the point where I just want to sell the car like it sits because I'm extremely fed up with it and sick of doing nothing but working on it. I think I would be better to just take my losses and get rid of the damn thing.
If you follow the checklist, it will help you fix 95% of the cranks OK but no start problems.
The spraying ether usually makes the car run badly, it is just a trick to see if you have fuel management problems or an ignition problem. It sounds like a fuel managment problem, since the car will fire off when you do the ether trick. Concentrate on the fuel management items on the checklist.
Use a pressure gauge to look for fuel pressure. A tire pressure gauge appliled to the schrader valve will work in a pinch if you don't have a regular FP gauge.
The computer will shut off the injectors after prolonged cranking OR if you press the throttle wide open.
A Noid light available from Autozone, is one way to test the injector wiring. I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
There are two 10 pin connectors at the back of the upper manifold, one of them has all 8 injector connections. Pull them apart and check for damage. Each injector should ohm out at about 13 ohms +\- 1.5 ohms.
Remember that the computer supplies a ground path for the injectors. The power for the injectors comes through the ECC relay located on top of the computer. They have power to them any time the ignition is on. The computer turns on the ground and completes the circuit, making the injectors fire. . Pull an injector wire connector off and look for 12 volts when the ignition switch is on. No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold). No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Another thought - the HO computer will not work with a non HO engine and the same is true of a non HO computer- it won't work with an HO engine. As long as you have an HO engine from a Lincoln LSC you are OK in that department.
Did you pull the distributor out of the engine on install by any chance? I remember when i did my motor, i put my distributor in 180 out, didnt want to start at all, just turned over. Then put it in "right" and got one tooth off, extremely hard to start.... ran really badly, and when i hit the gas it would really hesitate and would not rev... Thats just the after affects of having the distributor one tooth off... So make sure it is on the right tooth, if not, you probably wouldnt start, or it would run really badly.... hope this helped.
This "One Tooth off" thing has been debated and debunked here on Stangnet more times than I can count. :nonono: There is no such thing as "one tooth off" as long as you can make the timing marks line up when you put the timing light on the engine and set the timing. That's why the distributor rotates in its mount so you can make the marks line up. Anyone who tries to install a distributor without using a timing light to set the timing is bound to be off by several degrees or more, either late or early.
I agree with you, but here we go again. This damn topic of one tooth will never die.
just calm down and recheck everything. If you dont have the interest anymore, get a bud to do it for you (bud,bro,pops whomever). A fresh set of eyes may help. Let them go at it their own way so they can find what you missed (if anything).
Too bad NM is so damn far away. I have some money burning up my pockets. I would love to find a cheap car.
Well I got my starter issues fixed, it was a bad flywheel, so now my starter is good atleast. The car still wont start though. It is kind of hitting, and it almost starts but it doesnt. I pulled the number one plug and it has fuel on it so I know it is getting fuel there. However, I pulled the number 7 plug and it was bone dry. So apparently onle some cylinders are getting fuel. I'm going to pull all plugs tomorrow to see which are and arent getting fuel. Could this be from the injectors being bad or the injector wiring harness? The injectors are just stock ones out of the motor so they were sitting for a wile in the motor before it was pulled. Could this make them go bad or does this not sound like an injector problem? Thanks for all the help.
If you have some extra time... try this. Pop the valve covers and hand crank the motor over starting at cylinder 1 at tdc. watch the intake valve open then close. follow this proceedure for the next moving intake valve. Write donw the order and this should tell you wether or not you have an HO cam or not. I forget the 2 timming sequences offhand, but i am sure someone has them and will be nice enough to post to help you out. Then according to the dictation of the valve, wire the cap accordingly.
The bone dry and soak plugged throw a flag too. I would be sure that all connections are good on the injectors, maybe clean them with some contact cleaner and regrease with dielectric grease. also take a peep at the 10 pins and make sure they are clean and grease them up too. And if you have time, pop the injectors and make sure they arent clogged up (my van's fuel rail rusted out and clogged the injectors, now it hesitates a tad, but i am still driving it till i can find some new ones).
Let us know how u make out guy. Just go through and recheck every wire with a bud as noted by a few people, it will pay off in the end.
