New Mustang Steering Product
Power Box Application Details
1965-1966 Mustang (1” Diameter Sector Shaft)
Factory P/S Cars Require:
Power Steering Box
Power Steering Hose Kit
Steering Column Shaft / Floor Mount
Complete Rag Joint
65-66 V-8 M/S Center link
Manual Steering Cars Require:
Power Steering Box
Complete Rag Joint
P/S Pump, Bracket and Pulley Kit
1967 Mustang (Must verify sector shaft diameter 1” or 1-1/8”)
Note: Cars with ¾” Diameter non-collapsible column shaft will require part #990040 Steering Column shaft/ floor mount and #052534 Complete Rag Joint not ½ rag joint.
Power Steering Box
½ Rag Joint
Drag Link Adapter
Power Steering Box
½ Rag Joint
1968-1970 Mustang (1-1/8” Diameter Sector Shaft)
Power Steering Box
½ Rag Joint
Drag Link Adapter
Power Steering Box
½ Rag Joint
Power Conversion Box Part #'s
Mustang Conversion Part #’s
800110 – Power Steering Box, 65-67, 1” Diameter Sector Shaft
800111 – Power Steering Box, 67-70, 1-1/8” Diameter Sector Shaft
990040 – Steering Column Shaft, with Floor Mount1965-1967 (Early)
925107 – P/S Hose Kit, Ford Conversion Box to Ford Pump
925108 – P/S Hose Kit, Ford Conversion Box to Saginaw Pump Upgrade
052534 – Rag Joint, Conversion Box to Borgeson Column Shaft
990016 – ½ Rag Joint, Conversion Box to Rag Joint Flange on Stock Column
990003 – 1967-1970 Mustang Drag Link Adapter, Replaces Control Valve
990050 – 1965-1966 V-8 Manual Steering Drag Link
800330 – 1965-1970 SBF Mustang Saginaw P/S Pump Upgrade Inc: Pump, Pulley, Bracket
Power Steering Box
Complete Rag Joint
Power Steering Box
Complete Rag Joint
Power Steering Box
½ Rag Joint
Drag Link Adapter
Power Steering Box
½ Rag Joint
Power Steering Box
½ Rag Joint
Drag Link Adapter
Power Steering Box
½ Rag Joint
will this box work on other ford vehicles that use the same steering gear? for example; ranchero, torino, falcon, fairlane, etc ?
What pitman arm does this piece use?
It will fit with any stock 1" or 1-1/8" Pitman arm. (We offer the box in both sizes) The lenght of the Pitman arm will however still effect overall steering speed. The box is a 16:1 ratio with 4 turns of the Input shaft lock to lock, a longer Pitman arm will speed that up at the wheels.
Thanks, Jeff
Is there any possibility of offering a discounted group buy to stangnet members?
Thats a tough one, we are a true manufacturer with an exisitng distribution network. We do sell all of our products direct however at full retail price to insure that our dealers an distributors can maintain the ability to make money on our products.
An idea on pricing
And idea on pricing for complete kits below. The most affordable R&P conversion that is complete is $1,599 and again our box retains a stock look, simplified steering linkage (to the column), full turning radius and full ground clearance.
Factory P/S Cars Require: $899
Power Steering Box
Complete Rag Joint
Manual Steering Cars Require: $1084
Power Steering Box
Complete Rag Joint
Factory P/S Cars Require: $860
Power Steering Box
½ Rag Joint
Drag Link Adapter
Manual Steering Cars Require: $996
Power Steering Box
½ Rag Joint
Power Steering Box
½ Rag Joint
Drag Link Adapter
Power Steering Box
½ Rag Joint
Refund for original box.
Included with conversion box is a form to obtain a $65.00 refund if you send us your original manual steering box. Even with the cost to ship us the box this is another quick $50 of the cost of the conversion.:nice:
I've got an '89 5.0 engine in my '66 with the serpentine setup. Would I have to adapt your pump or would the 89 model pump work?
Your 1989 5.0 pump should operate our conversion box just fine. I would need to know the high pressure fitting size on your pump to get you the proper hose kit.
Dealers / Distributors
All part #'s for Mustang conversion are now good with Summit, Jegs, Motorstate, and Keystone. We are busy getting more on board as fast as we can.
Thanks,
