Mods
Under drive pulleys, cold air intake, C&L plenum, accufabu 75 mm throttle body, stage 2 cams & heads, slp line lock, hurst short throw shifter, Leather shift & e-brake boot, blistein strut & skocks, h&r super sport springs, summitt caster & camber plates, steeda ball joints, steeda bump steer kit, 275/40/17, aluminium drive shaft, global west full lenth subframe connectors, 4:10 gears, steeda front & rear sway bar, welded axels, 4- 3/4 end links, poly bushings, rear lower control arm, rear shock tower brace, tuned by Tim Barth!
