NEW PROBLEM HELP PLEASE
1990stanglx
THIS MORNING I GOT IN MY CAR TO GO TO WORK WHEN IT STARTED THE ENGINE RATTLED BAD THEN IT QUIT WHEN OIL PRESSURE CAME UP .WHERE DO I START IT HOLD GOOD OIL PRESSURE AROUND 45 AT IDLE HOT. IF YOU LET IT SIT FOR ABOUT 30 MIN OR SO IT DOES IT AGAIN .I TRIED CHANGING OIL FILTER DIDNT HELP STILL DOES IT
hmm.....sounds like an oil pump might be going out. the pressure valve inside the oil pump should hold some pressure in the block along with the anti-drain back valve in the filter which is there to prevent dry starts
I would say its possible your oil pump is going. Now i am going to contridict my words. You have a gear oil pump and i was under the impresssion they either pumped or don't that being said my father tarus would lose oil pressure let it sit a while then it had it again for a bit. Took me forever to get the car home for him. It just had to have a new oil pump put in and it was fine. Thats where i would start with yours.
