  • 2.3L (N/A & Turbo) Tech
new problem
  • Thread starter Thread starter 93PONY
  • Start date Start date Mar 6, 2007
93PONY
219
pensylvania
Mar 6, 2007
  • Mar 6, 2007
hello my 93 still wont start, now when you turn the key it just makes a rapid clicking noise. has my starter died or is it my altenator? i tried to jump it at the solinoid and got the same results so i have ruled out the ignition switch. please help i need to get this thing back on the road asap.
HFK
20
Nokomis, FL
Mar 6, 2007
  • Mar 6, 2007
Where is the clicking sound coming from? The starter? The solenoid? Have you tested the battery to see how much power it has or tried to jump start it?
Stinger
7,754
24
118
Basehor (Kansas City), KS
Mar 7, 2007
  • Mar 7, 2007
Dead battery or bad battery connection. The clicking is the solenoid not getting enough power to stay closed...
93PONY
219
pensylvania
Mar 7, 2007
  • Mar 7, 2007
tried a brand new batt. and got same problem, do you think its the solinoid? and the sound just comes from under the hood. i just need to get it running so i can get it to my fatherinlaws garage to do my turbo swap, i have everything ready to go except for the exhaust but im not to worried about that right now.
K
kevinspann
Richmond, VA
Mar 7, 2007
  • Mar 7, 2007
Like Stinger says bad battery connection, check the cables, at both ends. If the solenoid was bad i dont believe that it would click
HFK
20
Nokomis, FL
Mar 8, 2007
  • Mar 8, 2007
A bad solenoid can/will click or do other strange things. I agree though to first check the cables and their connections. As for your original question if you have a fully charged battery and a good solenoid, connections and ignition no matter how bad your alternator is your 2.3 would start, so rule that out. After connections most likely with what you described is solenoid, especially if it is a cheap one from your local parts store. I went through 3 in under a year until I bought a good one and had many different starting problems each time and it was the solenoid.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
3K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
