New S/C - codes 92 & 42 help!
For stock vech fuel pres eng running 27 to37.engine off 35 to 45.when key off does it hold pres for 1 min?. Code 42 92 always rich.when u did your test u did run eng at 2000rpm for 2 min.also another note from book pull pcv when doing test .fuel in oil .also koeo test did 11 flash twice .this method gives continuous codes also.if by chance 42 is always rich 92 shift solenoid circuit failure. Im in sa 2hr road trip it be nice to have book in hand
Using cel for koeo test.c if u can follow this?this will be a perfect pass, blink half sec pause blink 4 sec pause blink half sec pause blink 6~9 sec pause half sec blink 6~9 sec pause blink half sec pause blink 4 sec pause blink half sec pause blink . Thats 11,11 service code pass 11,11 cont code pass
Thanks
Thanks HotCobra;
I get the 11 code twice so the koeo test shows OK, still getting 42&92 on the koer test. Timing at 15* has solved the stutter and pop at low rpms. I'm going to take the FMU and ignition retard vacuum off the FPR vacuum line and see if that helps. next step is definitely a trip to the dyno.
Thank you everyone for all your help.
