New S/C - codes 92 & 42 help!
  • Thread starter Thread starter Mike in Texas
  • Start date Start date Nov 1, 2008
First Prev 2 of 2
hotcobra03
poteet,tx
Nov 7, 2008
#21
  • Nov 7, 2008
  • #21
For stock vech fuel pres eng running 27 to37.engine off 35 to 45.when key off does it hold pres for 1 min?. Code 42 92 always rich.when u did your test u did run eng at 2000rpm for 2 min.also another note from book pull pcv when doing test .fuel in oil .also koeo test did 11 flash twice .this method gives continuous codes also.if by chance 42 is always rich 92 shift solenoid circuit failure. Im in sa 2hr road trip it be nice to have book in hand
hotcobra03
poteet,tx
Nov 7, 2008
#22
  • Nov 7, 2008
  • #22
Using cel for koeo test.c if u can follow this?this will be a perfect pass, blink half sec pause blink 4 sec pause blink half sec pause blink 6~9 sec pause half sec blink 6~9 sec pause blink half sec pause blink 4 sec pause blink half sec pause blink . Thats 11,11 service code pass 11,11 cont code pass
M
Mike in Texas
121
#23
  • Nov 7, 2008
  • #23
Thanks
Thanks HotCobra;
I get the 11 code twice so the koeo test shows OK, still getting 42&92 on the koer test. Timing at 15* has solved the stutter and pop at low rpms. I'm going to take the FMU and ignition retard vacuum off the FPR vacuum line and see if that helps. next step is definitely a trip to the dyno.
Thank you everyone for all your help.
hotcobra03
poteet,tx
Nov 7, 2008
#24
  • Nov 7, 2008
  • #24
Did u get 4 11s. Cause u should. Were thier any codes for constant
First Prev 2 of 2
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
