anyone else have a real hard time getting the crank gear on??? i had to use a pulley to get the old one off. any suggestions on how to get the new one on a little easier???
ok, fixed! FYI if anyone runs into this kind of problem, get out the dremel and slowly,carefully evenly and patiently grind away at the inside of the cam gear do a little at a time and keep trying to slide it on to the crankshaft until it goes on.... wallaaah done! this post is now closed :SNSign:
I bought the Edelbrock one and I noticed that it would just easily bind, so I had to tap one side then the other over and over while doing the same with the cam sprocket to get it on.
