Hello,
I Just installed new BF Goodrich Radial T/A 225/60R15 tires all the way around my 1966 Coupe. They are mounted on 15X7 styled steel wheels. They look great, but the front tires are just barely rubbing on the upper control arms. I should mention that the wheels are WAY out of alignment. There is EXTREME negative camber in the front wheels. Just by looking at the car you can tell that the alignment is way off. I also have 1" drop front springs installed.
Could this be the reason why the tops of the wheels are touching the upper control arms? Do I need to go with a more narrow tire up front, or can I use a spacer plate behind the wheel? I turned the wheels from lock to lock and there are no other clearance problems.
By the way, the rear tires fit very well. I probably could have gone a little wider back there.
Thanks,
Carl
Thanks,
Carl
