new to the forum...and mustangs
86lxhatch
113
East Tennessee
I'm on unfamiliar ground here...I just bought an 86 LX hatchback that has been converted to a 302 with c-4 tranny. I am interested in using this car for autocross/road racing and am in need of some advice.
This is what I have:
1985 non-roller block--bored .030 to 306, cleaned and honed, etc., etc.
stock crank--cleaned and ground down .010
The motor and trans are out of the car-gonna switch to a t-5(costly, I know)but I wanna shift my own gears.
This is where I need help and ideas:
I want to get to 350-375 rwhp naturally asp. with holley 4150 carb-650 cfm and some nitrous for playing around with.
Any ideas or suggestions would be appreiciated..I haven't bought any parts yet, other than some main bearings and plastigauge for installing the crank, so I am hoping to get a plan together before heating up the ole' wallet if ya know what I mean:D
I'm really interested in combinations that have already been done and and can be for lack of a better word, done again! with roughly the same results. I don't know anything about cams, heads, or intakes, but I know I need them all to be "big"...
Welcome to the mechanical drug world.......I think you need to look at your over all combination and true intentions, its good you ask for help and suggestions...I think for your horsepower range and looking into doing a motor build, I would do a stroker kit (mostly a 347) and of course a 8.8 rear end (if you havent swapped that yet). I would also seriously consider a quality suspension upgrade and what you want to do I would highly recommend a maximum motorsports suspension components (you can do a kit or do pieces as money allows). And also look into some brake upgrades too. The main thing to remember is, dont get in over your head and bust your budget as majority of people that ends up getting out of the hobby is mainly due to frustration and money issues.
And dont forget to do research and ask around on the forum twice as much....
To get to that kind of power N/A, you will need a stout engine. 347, aluminum heads (AFR, Trickflow,etc.) a custom camshaft, and of course a fuel system to support it. If you are wanting to autocross then I imagine you will spend a lot of time in the upper RPM range. Stock blocks are not great at higher RPMs, and sustaining them for long periods of time is not great either.
That being said, its all relative. If you could keep RPMs somewhere between 5500-6000 you could probably make a well built motor last. I would definetly consider doing a roller conversion so you can use a roller camshaft. The previous post about suspension and brakes are all great advice. I don't roadrace, so I know there are others on here who have actual experience in it and can give you much better advice. All the above is just my take on things.
Good luck with it!
Before you spend any money, check out the rules for Auto-cross in your area. Some of the mods you make may put you in a class where the competition is very difficult. Fewer mods may equal a lower class, less competition and more fun.
Cubic inches are going to be the fix for your hourspower goals. A 302 won't put out that kind of power without pressurized induction or NO2.
Either a 347 stroker or a 351W short block solves the cubic inch problem at about the same cost if you are a careful shopper. Some aluminum heads, suitable intake manifold and roller cam will be required for either 347 stroker or 351W. Since you are going to be pulling a lot of low RPM turns and coming out of the corners, you will need a camshaft with lots of low RPM torque. Thats the reason for the stock HO roller cam from an 86-93 HO Mustang. Combine that with an intake manifold with long runners and you will have lots of torque to come out of the corner and gain speed quickly.
Your brakes are going to take a beating, so here's what I would do. You''ll need some 87-93 5.0 Mustang front spindles to accommodate the 87-93 5.0 larger rotors.
The rear axle & disk brakes are another junkyard item:
Do the 87-88 T-Bird Turbo Coupe rear end swap!
Auto trans 87-88 Tbird Turbo Coupes come with 3.73 gears and manual Turbo Coupes come with 3.55 gears. Cost is $125-$300 for the rear axle. Add another $100-$200 or so to complete the brake upgrade.
I choose 3.55 since I do more highway driving. Both ratios have 10 5/16" disk brakes with vented rotors as standard equipment.
It takes 2 guys the first day to get the old rear end out and the new one bolted in place. It takes 1 guy another whole day to do the brakes.
You will need a several sets of fittings, I recommend that you get them from Matt90GT's website, 87-93* Ford Fox Body Mustang Brake Upgrades. Read Matt's instructions thoroughly, everything you need to know about the brakes is all there. You need to be patient and follow all the internal links, and there are many of them. You will need 2 fittings in the rear to adapt your old brake tubing to the TC disk brakes. The fittings go between the steel tube and the caliper brake hose. You will need another set of fittings to make a 2 port to 3 port adapter. To make life simpler, just buy the kits from Matt. You could piece them together, but it's not worth the time unless you work at an auto parts store with all the fittings ever made.
You will need to drill the quad shock mounting holes 2” below the holes drilled for the Turbo Coupe mounting points. The bolts are metric, so don’t loose them or the nuts. A 15/32” drill should be about the right size unless you have access to metric sized drill bits. Going without quad shocks is not an option unless you have aftermarket parts to soak up the wheel hop.
You will need a proportioning valve, Summit has one for $40 + shipping.
You will need a kit (FMS makes the part) to gut the stock proportioning valve, Summit also has that, about $10.
You will need a new master cylinder, see Matt's site and make you choice. I used a 94-95 Mustang master cylinder. Note that rebuilt 94-95 Mustang master cylinders do not come with a reservoir. That means a trip to the junkyard and some more money spent.
Your brake pedal may be very hard and almost impossible to lock up the brakes. I had to replace the front calipers with 73 mm calipers from a 91 Lincoln Mark 7 to get the braking performance up to par.
Bleeding the brakes will require 2 people and some coordinated effort. I don’t recommend using you wife or girlfriend to pump the pedal – they get offended when you yell at them. I used a homemade power brake bleeder constructed from a garden sprayer and some fittings from Home Depot. It cost about $25 and was worth every penny. See how hard is it to bleed brakes? - Mustang Forums at StangNet for details and pictures.
See Mustang Central.net FMS M2300K Brake Install for help with the emergency brake. The red words link to some very useful photos on how to modify the handle. The stock setup tends to lock up and not release properly.
All in all I have been very pleased with the results.
Turbo Coupe parts list:
87-88 T-Bird Turbo Coupe Rear axle
94-95 Mustang Master Cylinder with reservoir
Brake line Adapter fittings 87-93* Ford Fox Body Mustang Brake Upgrades.
3 line to 2 line brake fitting kit 87-93* Ford Fox Body Mustang Brake Upgrades..
Proportioning valve, Wildwood 260-8419 Summit or Jegs
Kit to gut the stock proportioning valve Ford Racing M-2450-A Summit or Jegs
Reuse stock brake booster – no changes needed with the parts in this list
73 mm front calipers from a 91 Lincoln Mark 7 (two calipers) local auto parts store
Emergency brake cable parts: Summit or Jegs or Late Model Restoration
79-92 Mustangs use: M-2809-A* Parking Brake Cable (need 2)
93 Mustangs: use 93 Cobra Ebrake cables.
All years use: M-2810-A* Parking Brake Cable (short cable that attachés to the parking brake handle)
I recommend that you use reman calipers and use the calipers from the Turbo Coupe axle for cores to return. The parking brake mechanism and the caliper slides tend to lockup and freeze
Identifying a Turbo Coupe rear axle:
1.) Measure the rotors - a TC disk brake uses 10 5/16" vented rotors.
2.) Measure the length of the quad shock mount arm and compare it to the mount on your existing stock axle. The TC quad shock mount arm is about 8" long if I remember correctly.
3.) Measure the distance between the axle flanges and compare it to stock. The TC rear axle assembly is 3/4" wider per side, or 1 1/2" wider for both sides.
Five lug Turbo Coupe conversion:
Use the 94-98 axles Mustang axles. Use 1990 Mazda MPV 3.0 V6 front rotors (10", 5 lug x 4.5" pattern, 2 7/16" offset ). While you are at the auto parts store, set a TC rear rotor side by side with the Mazda rotor and they are the same except for the offset.
The next step fixes the offset problem:
Use a Maximum MotorSports 1/8 spacer (MMWS6, Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader! ) between the inside of the rotor and the axle flange. The spacers may need to have the OD machined to fit properly. The stock rotor offset is 2 5/16" and the Mazda rotors are 2 7/16" offset. The 1/8" spacer puts the rotor back dead center alignment with the calipers.
The Mazda rotors are under $30 each, and I have seen them for $20 each. The MM spacers are two for $30 + $9 shipping. So the entire package costs $99. That saves $41, which most of us could find a very good use for.
The T5 5 speed is going take a beating in 1st & 2nd gears doing Auto-cross, so either make plans to shell out a lot of money to keep fixing it or buy a Tremec 3550, TKO or TKO500 or TKO600 up front.
You'll need subframe connectors as the minimum chassis upgrade: shocks and good control arms will also be needed.
Thanks for the ideas, I will need to do some more research. The 347 idea sounds good, but I will have to scrap the stock crank. A 351w sounds like the ticket, but do you all know what years the 351w started with the roller blocks?
So I have been looking at the eagle rotating assemblies at summit for a 347, and they seem somewhat reasonably priced. I guess I feel like since I already have the motor out, I should go ahead and build it the way I want it, rather than rebuild it somewhat stock, then get frustrated with the lack of power, then have to turn around and build another one...know what I mean?
So here's my new question for the day--is it possible to do the 347 stroker kit, put an aggressive flat tappet or solid tappet cam in the non-roller block, add good flowing heads and achieve 350/375 hp n/a?
jrichker,
Thanks for the suspension and drivetrain tips...I'll definitely be doing a lot of that stuff once I get this car running again. I guess right now I'm only focused on motor and tranny because they are both preventing me from getting back on the street. I am new to autocrossing, but I figured that would be a good place to start so I can learn how to drive the car on edge, but maintain control, and also learn the rules and tactics of making good times while having fun. I saw some NASA events that were on road tracks like Road Atlanta, etc. This is the kind of racing I would eventually like to do (road courses)
The more I look at it though, the more I like the idea of the 347 stroker kits. I want to keep my 302 block(even though it is not roller) and try for the 375hp mark without the roller cam. Does anyone on here have a setup like this?
