Thank you for the welcome! And thank you for the info! I have owned her now for over ten years, I have massed enough parts to do the front end, BTW it is a QA1 front end kit( the CC, bumpsteer, coil overs and struts, K member, tubular control arms with heim joints) I have new lines( high pressure and return) and a new rack for the front end, all I need is a new power steering pump( any suggestions on the best and cheapest place for this part?) I have a set of long tube headers ( pace setter from RacerWalsh) that I will be putting on as well. For the back I have mac upper and lower control arms, waiting for the money to buy some lowering springs and some spherical bearings. I also need a rear swaybar and tpr bushings and some quad shock mounts, then the suspension will be able to chill till everything else is up to par.
I don't know if you guys do alot of write ups here. Does anyone here do write ups on their different projects? The reason I ask is that the 2.3L is kinda like the performance of the SHO, there is a huge potential, but information is limited. I have seen the cold-air project. I will take pictures of the process and do a write up on it so that anyone else that wants to do this in the future will have a guide.
