New twin turbo kit for 2003 Cobra
Islander03GT said:
$8200 good lord thats alot of money!
i know it's a lot but considering u will get all of these ( with that price u still save a lot of money to reach to that power with other company )
Stage 2: 600rwhp @ 8-9psi
Two Turbonetics 60-1 HiFi Hybrid Turbos (water cooled), Polished compressor housing
2000 Degree Thermal Barrier Coating of Turbine
Two TiAl 38mm HP Wastegates - anodized
Custom Spearco Intercooler (supports 700+hp)
Eight 55# Fuel Injectors
'03 Cobra Fuel Pump
'03 Cobra Fuel Tank
Custom Tuned Computer Chip
ProM Univer Plus MAF - custom made for our applications
Two 304L Stainless Steel Turbo Headers - mandrel bent
Two 304L Stainless Steel Turbine Flanges - CNC cut
Two 304L Stainless Steel Downpipe Flanges - CNC cut
Two 304L Stainless Steel Downpipes - mandrel bent
Two 304L Stainless Steel Downpipe Connectors (connects downpipes to factory exhaust) - mandrel bent
Two 304L Stainless Steel Air Filter to Turbo Inlet Tubes - mandrel bent
Two 304L Stainless Steel Turbo to Intercooler Tubing - mandrel bent
One 304L Stainless Steel Intercooler to Intake Tubing - mandrel bent
Two K&N Air Filters
Custom Fabricated Power Steering Resevoir Bracket
Custom Coolant Degas/Overflow tank
Custom A/C Lines
Custom Boost Controller Bracket
Custom Fabricated Coolant Crossover Tube
Custom Fabricated Oil Filter Relocation Mounting Bracket
Custom Fabricated 304L Stainless Upper Radiator Hose
Custom Block to Thermostat Hose
Custom Thermostat to Radiator, Lower Hose
Custom Modification to Oil Filter/Coolant housing
AJE Racing Tubular k-member
Performance Exhaust Gaskets
TiAl Blowoff Valve - anodized (Silver, Titanium Gray, Red, Blue or Purple)
Reinforced Silicone Hose Connectors (hand-laid)
Stainless Steel T-bolt Clamps - aircraft grade
Dual Oil Feed Fitting
Dual Water Feed Fitting
Battery Relocation Kit
Autometer Boost Gauge
Stainless Braided Oil Lines w/ AN Fittings
Stainless Braided Water Lines w/ AN Fittings
Ball-Flange Kit
EGR Fitting
TurboXS Manual High Performance Boost Controller
DEI Heat Shielding
Stainless Band Clamps
All Hardware
$8200*
Pricing may vary depending on the year of car and if it has a return style fuel system.
Stage 3 - Race/Tuner Packages: 1300hp @ 30psi
We can provide you with everything included in Stage 2 plus an upgrade to 62-1 Turbos (+$200) and the Race Intercooler that supports 1000+hp (+$500) for an incredible street/strip package.
As always, any of the components can be deducted from our kits. So for the tuners out there that already have many of these components, or do their own tuning, already have a fuel system or whatever, you only purchase what you need.
