  • 2.3L (N/A & Turbo) Tech
New U-joints too short
  • Thread starter Thread starter goland55
  • Start date Start date May 12, 2007
goland55
2,847
New Bedford, MA
May 12, 2007
  • May 12, 2007
I got some u-joints from Advance to put on the T5 driveshaft that I'll be using once I install my T5 that I've just rebuilt and the u-joints are way too small to be used. They were 1-0153's which is what they should be from what I can tell. So I got curious and looked up u-joints for a 92 LX with a 5.0 and 2-4800 u-joints came up as an option. I took some measurements and I'm pretty sure the 2-4800 is what I need (about a half inch longer each way). Has anyone else run into this?
The driveshaft and tranny all came from a junkyard 2.3. The tranny is def. a 2.3 T5 as the input shaft and bellhousing are the 2.3 design. Seems odd to me.
Brantley
1,329
Memphis, TN
May 12, 2007
  • May 12, 2007
Interesting.. I put u-joints in my driveshaft about 5 years ago. I had no issues with the correct parts.. And I think my 88 was an auto from the factory. It had a non-original trans in it when I got it, and I have no idea about the DS, however, it was a 4cyl shaft most likely.. based on the big ol weight/dingleberry up near the trans. I guess take 'em back and try the other ones. Who cares what they're for, as long as they fit correctly.
goland55
2,847
New Bedford, MA
May 12, 2007
  • May 12, 2007
Exactly. My yoke had the damper too (which I promptly removed, damn extra rotating mass). So I suppose that means it MUST be a 2.3 driveshaft. Oh well. Somebody on the assembly line must've been drinking on the job or something.
Brantley
1,329
Memphis, TN
May 12, 2007
  • May 12, 2007
You never can tell who's drinkin/doin what these days in factories lol that or illegal, non-english speaking aliens, but I won't get started on that subject. 'Nuff said.
On a side note, how'd you go about removing the dampner dingleberry? I beat the poo out of it with my 4lb BFH, and I got no where. I need to get that thing off the shaft, but I don't wanna damage the shaft in the process. I thought about cutting it in pieces with the sawzall, but that sounds like it'll take a while.
goland55
2,847
New Bedford, MA
May 12, 2007
  • May 12, 2007
I took my air sawzall and cut into the rubber around the very edge. I did this on both sides and then took a prybar and ripped the outer donut off. Then I just cleaned up the rubber with my airsaw and a wire wheel.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
May 14, 2007
  • May 14, 2007
I did the U-joints on mine about 2 years ago and I had no issues with the ones they gave me either
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
88 Foxbody 5.0 Driveshaft Issue! Need Help
  • James Hood
  • May 1, 2025
Fox 5.0 Mustang Tech May 1, 2025
AeroCoupe
