  • SN95 4.6L Mustang Tech
new upper plenum
  • Thread starter Thread starter bluidvl
  • Start date Start date May 24, 2006
bluidvl
63
delaware
May 24, 2006
  • May 24, 2006
just bought a true flow upper plenum it's the dragon plenum and a 70 mm tb am i going to have to get the computer tuned.sorry new to the 4.6 thanx and i did search the posts.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 24, 2006
  • May 24, 2006
No, but make sure the voltage is correct on the TPS and reset the PCM after the install.
bluidvl
63
delaware
May 24, 2006
  • May 24, 2006
thanx man same as 5.0 oh by the way the car is a 98 gt
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 24, 2006
+1 Your PCM will relearn your new mods after you reset it.
hotdog71
427
Seattle, Eastside
May 25, 2006
  • May 25, 2006
IMO you only need to check the voltage if you encounter a problem.
+2 Your ECU will learn new AF ratio's after you re-set it as stated above.
loosescrew79
313
  • May 25, 2006
If you disconnect the battery while the install, the computer will reset itself when you turn the vehicle back on. This way it won't take as long for the computer to re-learn the new settings.
shallowreef
illinois
May 25, 2006
  • May 25, 2006
I have the dragon performance TB and Plenum and i don't know about you guys who have accufab and what not but the dragon plenum whistles like a train. when its cold. Once it heats up its not as bad but until then it sounds like you have a whistle under your hood. Its still a great product and performs well. Its just that damn noise can drive you nuts sometimes.
hotdog71
427
Seattle, Eastside
May 26, 2006
  • May 26, 2006
Turn up your radio,,
sorry can help there I went with 75mm BBK TB/P combo
Satin Silver GT
127
Sagamore Ma.
May 26, 2006
  • May 26, 2006
I don't hear any whistle on my Accufab set up.
TrueBlue03
372
Bay Area, CA
May 26, 2006
#10
  • May 26, 2006
  • #10
i installed TB, Plenum and CAI all together and still do not hear any whistling or sucking noise at all while driving
....but maybe thats just because of my exhaust
shallowreef
illinois
May 26, 2006
#11
  • May 26, 2006
  • #11
Thats wierd that you guys don't hear that. Could i have a leak?
I talked to the owner of dragon performance and he said it was normal. I also heard that the little divider in the middle of the plenum causes the whistleing noise.
I'm confused.
DTNODYA
831
#12
  • May 26, 2006
  • #12
I'm confused.
You may want to make sure that your bolts that hold the plentum to the intake manifold are tightened to the correct torque specs. I think it's around 6 ft/lbs or 75-107 in/lbs .. but don't hold me to that ... my memory sucks.
Check your manual/haynes/etc., and make sure the bolts are snugged.
I had a similar issue with whistling and it turned out to be a loose (not like hand turning loose) bolt.
It's worth checking ...
TweekedGT
1,274
Alberta
May 26, 2006
#13
  • May 26, 2006
  • #13
I'm confused.
Mine has a slight whistle but mostly at WOT. It's just the higher volumeof air moving. If yours is real loud I woud check that out.
4.6_02_Black_GT
622
Charlotte NC
May 26, 2006
#14
  • May 26, 2006
  • #14
I have an Accufab TB as well..if I listen real close sometimes I hear a very slight whistle at part throttle.. I kinda like it.
bluidvl
63
delaware
May 26, 2006
#15
  • May 26, 2006
  • #15
cool thanx guys for all the input
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
