New (used) EEC, got codes to pull.... stumped.
  • Thread starter Thread starter Rick's Fords
  • Start date Start date Nov 8, 2006
First Prev 2 of 2
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 8, 2006
#21
  • Nov 8, 2006
  • #21
Code 22 MAP (vacuum) or BARO signal out of range. The MAP or BARO sensor is pretty much the same sensor for both Mass Air & Speed Density cars. The main difference is where it is connected. Mass Air cars vent it to the atmosphere, while Speed Density cars connect it to the intake manifold vacuum. Its purpose is to help set a baseline for the air/fuel mixture by sensing changes in barometric pressure. The MAP or BAP sensor puts out a 5 volt square wave that changes frequency with variations in atmospheric pressure. The base is 154 HZ at 29.92" of mercury - dry sunny day at sea level, about 68-72 degrees. You need an oscilloscope or frequency meter to measure it. There is no way you can use a common cheap voltmeter or DVM to accurately measure the output signal.
The MAP/BARO sensor is mounted on the firewall behind the upper manifold.
Baro or MAP test using frequency meter - run the test key on engine off. The noise from the ignition system will likely upset the frequency meter. I used a 10 x oscilloscope probe connected from the frequency meter to the MAP/BAP to reduce the jitter in the meter's readout.
If it is defective, your air/fuel ratio will be off and the car’s performance & emissions will suffer
Some basic checks you can make to be sure that the sensor is getting power & ground:
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery cablet. It should be less than 1.5 ohm.
The following power on check requires you to turn the ignition switch to the Run position.
Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or EGR sensors. Use the black/white wire for the ground for the DVM.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 8, 2006
#22
  • Nov 8, 2006
  • #22
now both heavy hitters of stangnet have jumped in. Your car will be running by tommorrow.
R
Rick's Fords
95
#23
  • Nov 8, 2006
  • #23
I believe he just said something I didn't think was possible, can I take the MAP out of a 91 5.0 HO LX and put it in to test?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 8, 2006
#24
  • Nov 8, 2006
  • #24
thats what it sounded like to me mind you in a 91 h.o. it isn't called a maps its called a baro.
R
Rick's Fords
95
#25
  • Nov 8, 2006
  • #25
I need to know now if this is possible, have a ride coming to pick me up in 10 mins to go get one.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 8, 2006
#26
  • Nov 8, 2006
  • #26
well i'm not sure. sounds like it but i don't know. Keep me updated as to how it works. nice talking to you and i hope i helped.
R
Rick's Fords
95
#27
  • Nov 8, 2006
  • #27
Well the MAP/BARO from the 91 MAF LX fixed something, but she's still not running right.
I did, however, manage to break a spark plug, and the boot/wire when doing my compression check, so I'll be replacing that sometime tomorrow. It's getting too late to check for anymore codes tonight as loud as the car is.
Thanks for all the help fellas, I'll keep ya updated.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 8, 2006
#28
  • Nov 8, 2006
  • #28
what did it fix? how is it running? what seems to be wrong still?
R
Rick's Fords
95
#29
  • Nov 8, 2006
  • #29
It's running 10 times better, not sounded like it's got a big ass cam in it. It's still not holding a steady throttle, there's a ticking from up front, doesn't sound like an internal though, I'll let you know what I find out in the morning, going to bed now Much happier.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 8, 2006
#30
  • Nov 8, 2006
  • #30
good. i'll look in on the post tomorrow.
R
Rick's Fords
95
#31
  • Nov 9, 2006
  • #31
Well, it's morning... here's the codes.
33 ALL - EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
41 System lean - Fuel control
91 System running lean - Fuel control
Here I go with some more searching.
R
Rick's Fords
95
#32
  • Nov 9, 2006
  • #32
Did some reading, 41 is left O2 sensor, 91 is right O2 sensor, both reading lean. Code 33 has something to do with my EGR, which I'm guessing since that vaccum line broke in the process of all this, it might need a replacement!
So now, new vaccum hose, set of plugs (for the broken one) and set of wires.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 9, 2006
#33
  • Nov 9, 2006
  • #33
Repairing your broken vacuum line may fix the EGR problem, but if it doesn't here's the test path.
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal flickers. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1 ohm.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve
apply 5in vacuum to the valve.
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect vacuum gauge to the hose coming off of the EGR Valve
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 5in vacuum?
if not, check for manifold vacuum at the EGR vacuum valve.
if you have manifold vacuum then connect vacuum gauge to the EGR valve side of the vacuum valve and snap throttle to 2500 RPM.
should read about 5in vacuum
The operation of the EGR vacuum regulator can be checked by using a test light applied across the wiring connector. Jumper the computer into self test mode and turn the key on but do not start the engine. You will hear all the actuators (including the EVR vacuum regulator) cycle. Watch for the light to flicker: that means the computer has signaled the EGR vacuum regulator successfully.
Code 41 or 91 - O2 indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
First Prev 2 of 2
  • brandyn200
  • Jun 20, 2026
AeroCoupe
new edge coolant leak need advice asap
  • 2vBoogs
  • Tuesday at 8:37 PM
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 4:38 PM
Mustang5L5
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
1987 Mustang GT Mass Air Conversion Help
  • mustangmike6996
  • Jan 1, 2025
2K
Fox 5.0 Mustang Tech Feb 4, 2025
mustangmike6996
