New Vortech MAF won't fix this will it?
pwcracer
347
Hastings, MN, USA
Since installing my SC my check engine light has been coming on under boost. I ran the codes and found this "Mass Air Flow Sensor above Max Voltage" Kenne bells solution was to lower boost, but I do not want to go backwards. My new vortech MAF is utilizing the stock sensor, so I am assuming I will still have my problem.
Yeah u are pegging ur MAF and im not surprised im pegging mine with just a H/C/I. What size injectors do you have right now? If you get a new MAF calibrated for say 30-36lb injectors you should not have that problem any more.
