new with custom suspension
  • Thread starter Thread starter 5280/4
  • Start date Start date May 21, 2009
  • 3
  • 4
First Prev 3 of 4 Next Last
T
thekid760
114
#41
  • Dec 25, 2009
  • #41
Bump. any new info? I'm interested.
201
#42
  • Dec 26, 2009
  • #42
The FVSA on my suspension is 100" from memory. I will have to go back and double check all my notes and calculations. I built everything in CAD at work and used that to check all the geometry.
TheKid,
thanks for the interest. I have been driving my car a lot and no issues very predictable handling. Maybe the end of january i will take it to the SCCA event at qualcomm just to have some fun.
Decurion
353
Livonia, MI
Apr 21, 2010
#43
  • Apr 21, 2010
  • #43
Ever get any track time with it, be it straight line or turns?
Wicked65
490
NORCAL
Apr 21, 2010
#44
  • Apr 21, 2010
  • #44
5280/4 said:
that is too cool!!!!!
well falcon65 was taken.
And so was Wicked65
Wildbill3
57
#45
  • Apr 22, 2010
  • #45
I would like to say im in also but im more into the roadcorse type driving pm me I will send you my # im doing a 66 coupe and im ready to start building the front now, im like you spending that much doesnt seem to cool thanks.... Bill
P
phutch11
328
Apr 22, 2010
#46
  • Apr 22, 2010
  • #46
5280/4,
Just to echo 10secondgoal, you really, really, really need to lawyer up, set up a LLC to protect yourself, and get as much liability insurance as you can if you are going to sell your plans - or have people "donate" money to you for them.
If you are not a PE and don't have liability insurance, I'd spend the money to have a PE put his stamp on your design as another safety factor.
God forbid if someone uses your design, and something happens - lawyers will drag expert witnesses in front of a jury to nit pick at every component of your design, fastner selection, safety factors, etc, etc, etc.
It is a sad fact that this is simply the truth for the society that we live in.
That said, it looks like a sweet little setup.
Good luck...
201
#47
  • Apr 23, 2010
  • #47
Hey Guys,
I havent been on here in awhile. So i agree about talking with a lawyer to protect myself. I am a mechanical engineer but not a PE. At the moment I will not be selling any of my plans or designs.
As for track time, not yet. I was designing and building a coilover suspension for my dads 65 mustang. Its a bolt in conversion using stock control arms. This one got to see some time a tthe drag strip. the front suspension performed as planned. My car needs some more work before I can get it to the track. hopefully a SCCA event this summer and maybe a weekend at the drag strip.
I am currently in Escrow, trying to buy my first house. so that may really delay the progress on my car.
Wildbill3
57
#48
  • Apr 23, 2010
  • #48
ok I have a???? for you are those stock spindals/drum or disc? is that a Willwood caliper / rotor setup.Can I ask how long were your UCA's?How long were those shocks,what spring did you use I can do this.but a little help.ya know racing has alway been a dangerous sport when **** happens on track thats wee it stays. Thers no warranty expressed or implied or asked for.Thanks Bill Hughes
201
#49
  • May 3, 2010
  • #49
Stock V8 drum spindles, wilwood kit 11.75 rotor. UCAs are 9.5" this is from memory i dont have access to my suspension analysis. 300 lb spring. 7"travel AFCO shocks.
did i get all answered.
201
#50
  • May 5, 2010
  • #50
Mostly fabbed everything. The ball joints are afco chrysler style screw ins with the correct taper. I think K727. And threaded ball joint holders. Everything else is materials and fab work. Afco shocks are 3870 T2 double adjustable. Oh and 3/4" chromoly rodends.
bnickel
5,640
lubbock, texas
May 5, 2010
#51
  • May 5, 2010
  • #51
what are you using for strut rods and most importantly ,for me anyway, where did you get the front mounts for the strut rods? they look very much like TCP pieces.
201
#52
  • May 5, 2010
  • #52
The front mounts are TCP. I hate how heavy they are. I will be changing those to another design that I have come up with. The advantage of the TCP swivels was it got the mock up and build completed much faster while I pondered a better solution for teh k-strut.
The strut rod is an afco swedged steel tube 3/4-16 LH/RH threads.
bnickel
5,640
lubbock, texas
May 5, 2010
#53
  • May 5, 2010
  • #53
hmmm, well when you're ready to ditch the TCP parts let me know, i'd definitely might be interested in buying them from you.
Wildbill3
57
#54
  • May 5, 2010
  • #54
Thanks for putting all that up it helps a ton!
201
#55
  • May 5, 2010
  • #55
Bnickel,
sounds good i will try and remember that when I take them off.
L
lauras70mach1
202
minnesota
May 7, 2010
#56
  • May 7, 2010
  • #56
Did you fabricate the shafts for the upper a-arms or did you source them somewhere?
201
#57
  • May 12, 2010
  • #57
The UCA shafts are from TCP. I bought them for $25 from TCP. I could not build them for that.
L
lauras70mach1
202
minnesota
May 13, 2010
#58
  • May 13, 2010
  • #58
The only ones I see on the site are the offset ones and they list them for $60 apiece. Still cheap... I'm looking for a shaft I can use with roller bearings in the stock uppers but maybe I'll do what you did. Most of the shafts are for chevys and the mounting bolts are too far apart and a lot of them are so wide they won't fit inside the shock tower.
201
#59
  • May 13, 2010
  • #59
Yes the TCP shafts are available if you call them. The drop shaft were not ideal geometry for what I wanted my susepnsion to do. I think DAZE and Maier and Opentracker all have shafts for the roller bearing conversion.
L
lauras70mach1
202
minnesota
May 13, 2010
#60
  • May 13, 2010
  • #60
How do the heims on the shaft on your arms like the angle?
  • 3
  • 4
new member
  • kb65
  • Jul 25, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 1, 2026
apple99Mustangdude
A
Glad to be here
  • josep4
  • Aug 7, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
DadLife0724
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
P
New here
  • PortCity
  • Jun 9, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 9, 2026
AeroCoupe
