I have read you do not want higher than 650 cfm for carbs on a 5.0 and the other guys are right those demons are supposed to be one of the best and even edelbrock has both good carbs and intakes. I am planning on a weiland? is it dual plane high rise or edelbrock intake I am trying to buy used where I can.
As for the castor cambor plates they are more of a priority if you lower your ride height and I would not consider that a priority purchase right away. Along with a bump steer kit.
You wanna get full subframe connectors as one of your first steps
it will help your car alot.....not much you can see but it will tighten your car up and will rattle less, will close better it is just a good idea and one of the most common cheap mods for stangs.
You also want to get rid of your weak 7.5" rearend and upgrade to 87+ 8.8 and get higher gears 3.73's at least....4.10's for me.
True about the brakes....but be careful and you can do that when you can afford it or find a donor car.
You are going to find you need traction I figure......so you wanna get new upper and lower control arms to help plant the tires not a necessity but they sure help.
Another cheap mod is underdrive pullies that free up some horsepower and even an electric fan is a good idea. You can get these out of other cars and make them work.
Another thing you would like is an aftermarket shifter I have a B&M Ripper but there are other ones like Pro 5.0, Steeda, etc some people like better this makes driving funner.
There are a few but it all cost money, and there are many more.
As for the 85.5 I never heard of that , late 84 cars have drag shocks and some other 85 items that most 84 do not have so some would call those later cars .5 years......maybe it is that kind of thinking otherwise???????
Great post I love talking about 85's.
