newbie classic high compression engine question
  • Thread starter Thread starter Hoyt Clagwell
  • Start date Start date Dec 18, 2004
H
Hoyt Clagwell
  • Dec 18, 2004
Reading the hardened valve seat thread got me thinking about leaded vs unleaded gasolines.
What is the impact of using todays 90+ octane unleaded gas in the older high-compression engines? Are octane booster additives needed for the older high compression engines (351 / 428 / 429 ) ?
Thanks.
D
D.Hearne
11,730
south louisiana
Dec 19, 2004
  • Dec 19, 2004
Thanks.
Extensive use of unleaded will let the valves pound themselves into the seats. I've been running CD2 lead substitute in the gas I run in my 68 Merc's 390 to prevent that. Can't tell you how well it works though, it's been running off and on for two years now ( car is parked currently) without adverse effects. Only pulling the heads off will tell me how well it does work. And I ain't about to do that. As for octane boosters, I've yet to run across one that actually works. Best thing for an engine like that is to swap cams to one that's got more overlap. That's what I did with the Merc's 390, it's got 10.25 to 1 compression and a Crane 272 degree Energizer now and runs fine on 89 octane mixed with CD2 lead substitute. With the stock 10.5 to 1 ratio and the stock cam, it would ping on 93 octane.
HistoricMustang
2,359
Confederate States of America
Dec 19, 2004
  • Dec 19, 2004
rbohm
6,698
550
204
tucson,az
Dec 19, 2004
  • Dec 19, 2004
HistoricMustang said:
agreed
D
D.Hearne
11,730
south louisiana
Dec 19, 2004
  • Dec 19, 2004
HUH? What's that about?
2bav8
2,511
Mesa, AZ
Dec 19, 2004
  • Dec 19, 2004
Historic really likes the "tech" question.
Max Power
1,774
St Paul
Dec 19, 2004
  • Dec 19, 2004
Or the answer....
H
Hoyt Clagwell
  • Dec 19, 2004
D.Hearne said:
Extensive use of unleaded will let the valves pound themselves into the seats. I've been running CD2 lead substitute in the gas I run in my 68 Merc's 390 to prevent that... As for octane boosters, I've yet to run across one that actually works. Best thing for an engine like that is to swap cams to one that's got more overlap. . With the stock 10.5 to 1 ratio and the stock cam, it would ping on 93 octane.
Thanks for the response - What was the impact on performance with the new cam ?
btw - did I post this in the wrong forum ? Apologies if I did.
HistoricMustang
2,359
Dec 19, 2004
  • Dec 19, 2004
2bav8 hit on it, but in todays "politically correct" world it will no longer be used.
We certainly do not want to "piss" anybody off, especially those with chrome wheels.
HistoricMustang
www.historicmustang.com
D
D.Hearne
11,730
south louisiana
Dec 20, 2004
#10
  • Dec 20, 2004
  • #10
The performance is fine with the new cam. Idles almost like the stock cam, only when cold, can you hear a hint of "lope". This 4200 lb hunk of iron runs mid 14 sec 1/4's with it. Engine is stock except for the cam and headers. I also added a 428 PI intake and 750 Holley carb. Also swapped the rear gears from 2.75's to 3.70's.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
J
Electrical No crank no dash no nothing, troubleshooting leads to more questions
  • Jojam99
  • Jun 2, 2022
3K
1994 - 1995 Specific Tech Jun 2, 2022
Jojam99
J
