Hi there, I am new here... in fact this is my first post and I need some help with a project i have. I am in Iraq right now and my girl told me that the car was leaking all over the garage and it was "stinky". It is an 89 lx with about 146k on it. it is stock exept for mac exhaust and pypes o/r xpipe. my mechanic said that it''s leaking oil from the back of the driver side valve cover and from the back of the intake manifold, and quite possibly the rear main seal as well but he's not sure yet. i got to thinking, the motor doesn't have much left. nows a good time to yank it out and go through it. i just found out that i''m going to be a father shortly after my return! so this is a budget built. that''s were you guys come in.
my mechanic suggested boring it out .030, dropping in a new set of pistons, adding a little "junk talking" lunati cam (don't have specs), a set of shortie headers, and opening up the stock heads. I decided to go a little farther with it though. I'm going with some alluminum heads, 24lb. injectors, bigger fuel pump, new intake manifold, TB and MAF sensor(not sure what size to use though), CAI, gears(3.55's out of my '06 or maybe 3:73's), MSD 6AL ignition, and a new coil. This car has an AOD so i told him to go through it also. Are there any recommendations for beefing up the tranny as well. I know B&M makes a "transkit" performace shift kit and a master racing overhaul kit. Would one of these be a wise decision? Anything else...manual valve body, torque converter, etc. I'd like to put a B&M hammer ratchet shifter just to make it a little more fun.
1. I'm leaning toward the polished cobra manifold with GT40x heads. Any other suggestions?
2. What size TB and MAF sensor for this set up?
3. What kind of power will something like this make?
4. Am i missing anything?
5. How much stall on torque converter?
6. What gear ratio did this car come with from the factory? I've been told 2:73 and 3:05
My goal is to have a RELIABLE lil ride thats quite a bit quicker and way more fun to drive that what it is now. This is my daily driver. The others stay in the corral waiting to stretch their legs a bit on the weekends. I apologize about the length. I've asked around a bit but didn't get much feedback yet. I sure do appreciate all the help. I'll be like a whole new car when i get home! :SNSign:
HUTCH
HUTCH
" suggests
