  • 2005 - 2009 Specific Tech
Newbie ? on Gear Ratio
  • Thread starter Thread starter 07gtcs
  • Start date Start date Dec 18, 2006
07gtcs
31
  • Dec 18, 2006
My 07 came with Limited Slip 3.31 ratio. Could someone give me a quick explanation on the gear ratio. I understand Limited Slip, but I really don't know about ratios. My guess is that a 3.31 gives you more top speed? and the higher ratio you go will give you more low end???
metroplex
405
SE MI
Dec 18, 2006
  • Dec 18, 2006
double tap
metroplex
405
SE MI
Dec 18, 2006
  • Dec 18, 2006
This ratio refers to the ring and pinion gear ratios in the rear end of the vehicle (# of teeth on ring gear divided by # of teeth on pinion gear). There was an optional 3.55 ratio for 07 GTs with the manual transmission. Due to the gearing on the automatic, the 3.31s aren't too bad. The folks with manual transmissions may want to start with the 3.55s for better acceleration from the showroom.
Many owners have upgraded to 4.10s for even faster acceleration.
07gtcs
31
  • Dec 18, 2006
Got it...thanks.
Power4
200
Rochester, NY
Dec 20, 2006
  • Dec 20, 2006
Is there any advantage to having 3.31s over the 3.55s?
anthony05gt
1,262
Maryland
Dec 20, 2006
  • Dec 20, 2006
All '07 GT's have 3.31 gears unless you have the 3.55 option.
H
Hoboattacker
542
Baton Rouge (LSU) / Houston, TX
Dec 20, 2006
  • Dec 20, 2006
Gas mileage and top end. The lower the gear ratio (do I have that termanology correct?) the more top end and better gas mileage while cruising. Higher ratio means faster acceleration, less top speed, and less gas mileage.
3.31/4.10
top end/off-the-line quick
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Dec 20, 2006
  • Dec 20, 2006
Hoboattacker said:
Gas mileage and top end. The numerically lower (higher gears) the gear ratio the more top end and better gas mileage while cruising. Higher numerical ratio (lower gears) means faster acceleration, less top speed, and less gas mileage.
3.31/4.10
fixed
07gtcs
31
  • Dec 21, 2006
bigcat said:
fixed
So, 3.31s will give faster acceleration but less gas mileage? Is that correct?
metroplex
405
SE MI
Dec 21, 2006
#10
  • Dec 21, 2006
  • #10
If you are comparing 3.31s to 3.27s, 3.08s, or 2.73s then you are correct.
However 3.55s will yield slightly faster acceleration and less gas mileage versus 3.31s. Now if you go to 4.10s, it will yield much better acceleration and theoretically worse gas mileage compared to 3.55s
My Crown Vic has 3.55s from the factory and it SUCKS gas on the highway. At 65 mph, it is turning around 2200 RPM with the torque converter locked. At 75 mph, it is about 2600 RPM w/ the torque converter locked!!
For the 05-up GTs w/ the TR-3650 and 235/55R17 tires:
3.31s
65 mph 1700 RPM
75 mph 2000 RPM
3.55s
65 mph 1800 RPM
75 mph 2100 RPM
4.10s
65 mph 2100 RPM
75 mph 2500 RPM
As you can see, one benefit of a 5-speed transmission is better gearing. However, the TR-6060 in the GT500 yields similar RPM values in the 2nd OD gear (6) as the 5th gear OD in the TR-3650.
FWIW I paid the $87 for the optional 3.55s since I wasn't planning on ever swapping gears or tearing into the rear differential (unless it is to rebuild the T-Lok clutches with the carbon fiber clutches from the 03-04 Cobra). A clutch rebuild doesn't require removal of the ring gear from the carrier or removal of the pinion gear, so 3.55s will work fine for me.
Power4
200
Rochester, NY
Dec 21, 2006
#11
  • Dec 21, 2006
  • #11
Is there a significant difference in gas mileage between the 3.31s and the 3.55s? I can't imagine 100 RPM difference at speed could make that much of a difference. I was planning on opting for the 3.55s when I order my GT in a month but if I could get a couple MPG better with the 3.31s I'd leave it with those (since it'll be my daily driver).
metroplex
405
SE MI
Dec 21, 2006
#12
  • Dec 21, 2006
  • #12
I was in the same boat and people said the gas mileage difference between 3.31s and 3.55s was negligible. Note that if you buy the automatic trans, the 3.55s are not available as a factory option. It's only available as a factory option for the TR-3650 manual transmission.
iskwezm
4,159
20
79
Rowland Heights,California
Dec 21, 2006
#13
  • Dec 21, 2006
  • #13
im going with 4.30's next week. My buddy has them in his 06 auto and got 24 MPG on a recent rtip with his 4.30's.
metroplex
405
SE MI
Dec 21, 2006
#14
  • Dec 21, 2006
  • #14
He was probably doing all highway driving at 55 mph... :SNSign:
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
