Newbie ? on Gear Ratio
07gtcs
31
My 07 came with Limited Slip 3.31 ratio. Could someone give me a quick explanation on the gear ratio. I understand Limited Slip, but I really don't know about ratios. My guess is that a 3.31 gives you more top speed? and the higher ratio you go will give you more low end???
This ratio refers to the ring and pinion gear ratios in the rear end of the vehicle (# of teeth on ring gear divided by # of teeth on pinion gear). There was an optional 3.55 ratio for 07 GTs with the manual transmission. Due to the gearing on the automatic, the 3.31s aren't too bad. The folks with manual transmissions may want to start with the 3.55s for better acceleration from the showroom.
Many owners have upgraded to 4.10s for even faster acceleration.
Got it...thanks.
So, 3.31s will give faster acceleration but less gas mileage? Is that correct?
If you are comparing 3.31s to 3.27s, 3.08s, or 2.73s then you are correct.
However 3.55s will yield slightly faster acceleration and less gas mileage versus 3.31s. Now if you go to 4.10s, it will yield much better acceleration and theoretically worse gas mileage compared to 3.55s
My Crown Vic has 3.55s from the factory and it SUCKS gas on the highway. At 65 mph, it is turning around 2200 RPM with the torque converter locked. At 75 mph, it is about 2600 RPM w/ the torque converter locked!!
For the 05-up GTs w/ the TR-3650 and 235/55R17 tires:
3.31s
65 mph 1700 RPM
75 mph 2000 RPM
3.55s
65 mph 1800 RPM
75 mph 2100 RPM
4.10s
65 mph 2100 RPM
75 mph 2500 RPM
As you can see, one benefit of a 5-speed transmission is better gearing. However, the TR-6060 in the GT500 yields similar RPM values in the 2nd OD gear (6) as the 5th gear OD in the TR-3650.
FWIW I paid the $87 for the optional 3.55s since I wasn't planning on ever swapping gears or tearing into the rear differential (unless it is to rebuild the T-Lok clutches with the carbon fiber clutches from the 03-04 Cobra). A clutch rebuild doesn't require removal of the ring gear from the carrier or removal of the pinion gear, so 3.55s will work fine for me.
Is there a significant difference in gas mileage between the 3.31s and the 3.55s? I can't imagine 100 RPM difference at speed could make that much of a difference. I was planning on opting for the 3.55s when I order my GT in a month but if I could get a couple MPG better with the 3.31s I'd leave it with those (since it'll be my daily driver).
I was in the same boat and people said the gas mileage difference between 3.31s and 3.55s was negligible. Note that if you buy the automatic trans, the 3.55s are not available as a factory option. It's only available as a factory option for the TR-3650 manual transmission.
