hey guys i just had a few questions on some tranny things, first i was wondering only auto tranny's have torque converters right? and also what is like a shift kit and all that stuff u can get? what do they do? thanks
O and I must say, you are quite the post whore. like 24 hours ago me and you both had around 108 posts then i went to bed, and now you have 172! And thats not including the non tech posts you made in the talk section! But o well you are learning, and helping out as much as you can so its all good. Musclecarfan88 said:well now you know if you ever read about one.O and I must say, you are quite the post whore. like 24 hours ago me and you both had around 108 posts then i went to bed, and now you have 172! And thats not including the non tech posts you made in the talk section! But o well you are learning, and helping out as much as you can so its all good.
he called you a post whore
i think this would called 'case in point'shttygtstang said:he called you a post whore
The Shape, thank you for the correction. my bad. i figured by 87+ they had electronics in them (and thought i had seen people refer to AODE). again, my bad.The Shape said:Actually the AOD is the auto in the fox cars. It has no electronics.![]()
Good point on maintanace too HISSIN I know plenty of people who will run an auto tranny 70-80K miles and never change the fluid and filterHISSIN50 said:The Shape, thank you for the correction. my bad. i figured by 87+ they had electronics in them (and thought i had seen people refer to AODE). again, my bad.
you brought up a good point. ill preface it by saying that i dont have an auto, so what i say is from what i have read. in stock form, the AOD should be fine. when power and TORQUE is up, that is when one can run into trouble. but that is not unlike T5 problems when they see a lot more power.
plus a lot of autos are not well maintained - proper maintanance and upgrades, like The Shape did with his trans cooler, etc, will greatly improve longevity and tractability.
Then they complain when the tranny dies
