nhra rules
  • Thread starter Thread starter shttygtstang
  • Start date Start date Jul 4, 2004
shttygtstang
978
  • Jul 4, 2004
who knows the nhra rules im going to the track(race way park) i want to make shure i can run i have a convertable to
D
dug
56
norcal
Jul 4, 2004
  • Jul 4, 2004
make sure you've got a catch can for your radiator (aka radiator overflow) and i think if you run faster than 13.99 you gott have a roll bar. just go and see what happens
shttygtstang
978
  • Jul 4, 2004
well here are my mods it will be dynoed friday..aod all built up stall 4500.dacco torque converter .transgo shift kit.police interceptor sprag and band.high hp red clutch disks.harden input shaft.80mm maf.75mm tb. paxton sc 13psi .turbo xs bov.edelbrock intake manifold.stock heads ported.stedda fuel rais .255 pump. adjustable regulator. f303 cam.msd 6al ignition.mds blaster coil. msd distributor.36lbs injectors.cosmetic head gasket reduce copression 65 thousanth over reduce copression to 8.5 double timble cam gears .bbk headers xpipe no cats.flowmasters 40s. 18 in polo tires wraped in nitto extreme tires..i have a fogger system im thinking about using im not shure though wut do you think i should run and wut hp should i push(im installing all this monday exept the tranny i pick it up mon morn the cars stock now you should see my room)
do ineed a five point harness roll cage some one tell me i think ill go a little faster than 13.9
samuraichamploo
367
Beaumont, TX
Jul 4, 2004
  • Jul 4, 2004
Your gonna hit well over 13.9
Heres the deal.
There not idiots at the track, but they will gladly take your money.
The problem is, If you run better than that, You need a roll cage.
That means you will pay the same price as everyone for one run.
I only say this because I have a very similar setup to you, Only I have a 351 instead of a supercharger, 10:1 comp instead of 8.5:1 Trick Flow Heads instead of ported heads
750CFM holley carb w/ Torker II intake Instead of your intake.
All together, probly the same HP. And I can guarntee that I will break WELLLLL into the 12's.
85GTlover
704
  • Jul 4, 2004
Good luck at the races.
shttygtstang
978
  • Jul 4, 2004
Heres the deal.
its a victor intake manifold i no over kill but i got it for 300.... i didnt install the stuff yet should i put the head gasket asside and up the compression the heads need to go to the shop and be milled i can have em take alittle extra off oh i have arp head bolts :damnit: i was hopping to go into low 12s high 11s better put the fogger system on
393Bird
244
Clarksville Tennessee
Jul 4, 2004
  • Jul 4, 2004
Drive shaft loop 13.99 (8.59) For drag slicks only
5 or 6-point roll bar 13.99 (8.59) For convertibles only
5-point safety harness 13.99 (8.59) For convertibles only, SFI Spec 16.1
Helmet 13.99 (8.59) Snell 90 or greater
Drive shaft loop 13.00 (8.14) For “street” or DOT tires
Condensed Rules:
http://members.tccoa.com/392bird/nhrarules2.htm
Full Rules:
http://members.tccoa.com/392bird/nhrarules.htm
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 4, 2004
  • Jul 4, 2004
Before you insisted on using the thicker head gasket to lower compression ratio despite our warning you against it due to quench/detonation issues. Now you want to know if you should have the heads milled to increase the ratio? I'm confused....and I suspect you are too.
Rules vary from track to track -- we can tell you all sorts of stuff; but I'd contact the track and see what THEY say. Also, there aren't too many supercharged, sprayed efi motors out there that aren't chipped to optimize things, and to be sure a/f ratios are safe throughout the rev range. Who's doing your chip for you?
And best of all - how is a carbed, aluminum headed 10:1 351 a "very similar set up" to an efi, low compression supercharged 302?
shttygtstang
978
  • Jul 4, 2004
no not confused just thinking wut will make the most power with out stressing my engine to much i have no chip iwas told not to use one with this setup
samuraichamploo
367
Beaumont, TX
Jul 5, 2004
#10
  • Jul 5, 2004
  • #10
we just have some similar parts.
T
New here, just saying hi.
  • Tank Mechanic
  • Nov 1, 2025
  • The Welcome Wagon
The Welcome Wagon Nov 2, 2025
nickyb
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Self Tuning
  • Bib36`
  • Oct 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Friday at 8:51 AM
Mustang5L5
