  • SN95 4.6L Mustang Tech
Night and Day Problem Literally!
  • Thread starter Thread starter 281CI96Coupe
  • Start date Start date Apr 22, 2007
281CI96Coupe
233
  • Apr 22, 2007
Ok, here goes...When I drive my mustang at night the steering is nice a firm like it should be with a little bit of play in the steering wheel. Now the problem i am having is during the day it is very mushy/Loose when im driving around town or far away when its about 70 degrees out...the steering is all over the road and is very irrating to control...Its not an alignment issue because I got one already its just very weird...Its kinda like icecream lol, its hard in the refrigerator but when its out in the warm it looses its strength and melts...Thats how it is with my front suspension...Ball Joints been replaced too...
Nate
Shiroelex
There's nothing worse than aut
728
Westland, MI
Apr 22, 2007
  • Apr 22, 2007
I think someone tapped your foglight power off of your power steering pressure sensor.
Honestly, try draining some of your power steering fluid, and add some Lucas power steering treatment. That stuff worked wonders in my Supercoupe.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 22, 2007
  • Apr 22, 2007
I also think this is fluid related. Change the fluid, use the above mentioned additive.
281CI96Coupe
233
  • Apr 22, 2007
Omg, I never thought about that...Now that I think of it, the last time I looked its passed the max mark, second, how do you drain only "some" out?/? can someone guide me in the right direction
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 23, 2007
  • Apr 23, 2007
Its a hassle to do p/s fluid. Personally I would take it to a shop for that.
Shiroelex
728
Westland, MI
Apr 23, 2007
  • Apr 23, 2007
I just pulled the return line off of the reservoir. It's got a hose clamp on it. I put a transmission funnel up there, and let it pour down into a 20oz pop bottle. I'd reccomend draining out as much as possible, and putting in all fresh stuff. Get the front end on jackstands (Away from your tires!), and when you get the new stuff in, start the car and turn the steering wheel slowly all the way left, then back right all the way again, lock to lock. Do that a few times, and check the fluid again. You might have to burp some air out of the reservoir sometimes.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
9
97 Mustang Gt Vert Body Roll
  • 97Stangk5h
  • Jan 1, 2022
3K
SN95 4.6L Mustang Tech Apr 14, 2022
Bill95
J
Removed Ignition Cylinder - Problems, No Start
  • JayhawkGT
  • May 28, 2021
SN95 4.6L Mustang Tech May 28, 2021
JayhawkGT
J
V
Strangest problem in front end
  • V6_lives_matter
  • Sep 27, 2021
2K
2005 - 2014 S-197 Mustang -General/Talk- Feb 2, 2022
V6_lives_matter
V
